General
IHADAV8 Playground
Scan readings
Topic: Scan readings (Read 2541 times)
TurboCajun
Keith Theriot
Turbo Street Modified
PSI: 1
6 Packed
Scan readings
September 26 2015, 05:12:32 PM »
Just got my friends GN on the road, things look good on the PL and scan master except for the O2s , it's showing run lean after warm up it cycles and goes to 000 and stays there until you move the throttle, I also notice when cruising , any change in throttle speeding up , it also hits the 000 , so I put in a new 02 sensor and it's still the same . It's like it's reading and shuts off
Re: Scan readings
September 26 2015, 05:43:39 PM »
try unplugging the orange wire and resetting the ecm...
then look for a big air leak...pcv valve, leak between maf and throttlebody, etc.
Scoobum
Re: Scan readings
September 26 2015, 08:20:04 PM »
Cajun...what's the BLM's?
TurboCajun
Keith Theriot
PSI: 1
6 Packed
Re: Scan readings
September 28 2015, 02:05:07 PM »
if I remember right they were at 128 on PL but I will check when I get home to verify.
TurboCajun
Keith Theriot
PSI: 1
6 Packed
Re: Scan readings
September 30 2015, 09:10:01 AM »
looking at the log the Bls are at 129 when the 02s are reading 000. I noticed that it only does it at idle and part throttle , and not at WOT.
The owner took the car home with him to have it cleaned up , so next time I have it here I will do some more checking,
motorhead
PSI: 4
Re: Scan readings
Reply #5 on:
September 30 2015, 10:42:27 AM »
What chip is in that thing?
It sounds like it is staying in open loop (speed density) and not referencing the O2 (closed loop) until it gets upto a set load point. Which is backwards traditional methods.
General
IHADAV8 Playground
Scan readings
