Author Topic: tattoo gun 101  (Read 3516 times)
Offline Be4u
tattoo gun 101
« on: May 08 2006, 03:04:16 AM »
I opened up my printer to see if I could fix it. Suddenly, I saw a tattoo gun motor. I tested it with direct power and found out that I dont need something to reduce the speed. Woot!!!!
Save the bumper fillers!
Move to Canadia!
tattoo gun 101
« Reply #1 on: May 08 2006, 09:11:52 AM »
You must be bored!! lol
DCEPTCN
  • Guest
Re: tattoo gun 101
« Reply #2 on: May 08 2006, 12:34:02 PM »
Tetnis City, here we come!
Offline Be4u
Re: tattoo gun 101
« Reply #3 on: May 08 2006, 01:06:46 PM »
I definatly need a power reducer. Works but it's way too fast. I'm going to tattoo a picture of a butt on my butt huh huh huh huh (did that sound like Beavis?)
Move to Canadia!
DCEPTCN
  • Guest
Re: tattoo gun 101
« Reply #4 on: May 08 2006, 01:23:07 PM »
I see you kept an Arrogant Bastard bottle! Mmmm, I'll hafta get some tonight. You know, you're goin' to all this trouble when a REAL cutback (that's what they're called) can be had for as cheap as $200 in some cases.....then again, you could just go pay for a tattoo at a shop. Trust me, I'm still to this day paying through the nose to have old shit from when I was a kid covered up. Not worth it unless it's done right the first time, IMO. Also, a true autoclave uses heat to kill bacteria *AND* pressure to kill bacterial spores, which heat alone can't do.....so, it's a common misnomer that boiling a needle is adequate. Just something to think about before you end up with Hepatitis A, B, D, Z, 12, Y6, or however many types there are.
Offline Be4u
Re: tattoo gun 101
« Reply #5 on: May 08 2006, 02:10:05 PM »
Yeah, that devil on that bottle is sweet. I couldnt throw it away.
I was board and hadnt made a gun in 10 years. If you seen the crappy tatts I have you'd probably try to cut them off. Without ink I cant do anything.
I remember the days when I used to tat up my friends. Thankfully I was behind the gun and not under it. I wish I would have stuck with it.
Move to Canadia!
tattoo gun 101
« Reply #6 on: May 08 2006, 03:17:06 PM »
Especially that Liberace tattoo!
Offline Be4u
Re: tattoo gun 101
« Reply #7 on: May 08 2006, 03:22:28 PM »
Did y'all know that on the second part of the tour the chick asked me for the stamp, I pointed at my neck. They loved it!
Move to Canadia!
Offline Recklessrob
tattoo gun 101
« Reply #8 on: May 10 2006, 12:04:17 AM »
Quote from: "Top Speed @ Mon May 08, 2006 2:17 pm"
 :rofl; I was thinkin' the same thing.
Rob
Offline 87natty
tattoo gun 101
« Reply #9 on: May 10 2006, 12:18:06 AM »
I honestly couldn't stop laughing after I saw the zip-ties man. All you need is a spoon and some ink bro.
Offline Be4u
tattoo gun 101
« Reply #10 on: May 10 2006, 12:59:55 AM »
Quote from: "87natty @ Tue May 09, 2006 8:18 pm"
Hell yeah, gotta keep it high tech and use Buick parts.
Move to Canadia!
Offline Recklessrob
tattoo gun 101
« Reply #11 on: May 10 2006, 01:20:08 AM »
Quote from: "Be4u @ Tue May 09, 2006 11:59 pm"
In that case, you could probably hack up a pintle style fuel injector
to make the tatoo gun. You could feed the ink straight into it.
Rob
