Author Topic: Removing Headrests?  (Read 4113 times)
Offline 1KWIKSIX
Removing Headrests?
« on: September 14 2015, 07:01:54 AM »
Can anyone shed some light on how these things can be removed?
Not having any luck using a taped hack saw blade.
thanks
dave
Re: Removing Headrests?
« Reply #1 on: September 14 2015, 07:51:28 AM »
You'll need something thin like a spatula but only as wide as the base of the headrest that goes inside the seat.  There is a button that needs to be depressed to pull the headrest out.  The thin metal will cover the hole and the button will not be allowed to slide into the hole.  I found that it was somewhat easier to slide the head rest fully out and then slide the metal in till you feel the button.  Then push the head rest down along with the metal strip.  Then hold the metal in place and pull up on the head rest.  Good luck!
« Reply #2 on: September 14 2015, 10:17:56 AM »
Hacksaw.
« Reply #3 on: September 15 2015, 02:57:31 PM »
Yep. Just like breaking in a house with a drivers license.
Offline 1KWIKSIX
« Reply #4 on: September 15 2015, 05:04:23 PM »
Wondering if I should be inserting the thin metal wedge thingy in the front side or back side of the headrest?
thanks
dave
« Reply #5 on: September 16 2015, 07:45:28 AM »
I believe its on the back side but can be a 100% certian.  Slept since then...
« Reply #6 on: September 17 2015, 08:30:38 PM »
side where the notches are
