Author Topic: need help with installing power logger  (Read 5635 times)
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« on: September 03 2015, 08:10:10 PM »
I have PL on my computer already, I am installing a PL is a friends car and cannot get it to connect, can you run two different PL on one computer? .
Re: need help with installing power logger
« Reply #1 on: September 03 2015, 08:52:23 PM »
Does the PL on your laptop work in his car? If his laptop has 8.1...then go to the other board and follow Bobs instructions.
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #2 on: September 03 2015, 09:17:30 PM »
no it doesnt, it works on my car but not in his, I think that it has something to do with the Port or the update files
« Reply #3 on: September 03 2015, 09:28:59 PM »
Keith...for some stupid reason...PL only works on one port on my laptop. Have you tried both ports...or however many it has?
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #4 on: September 03 2015, 09:33:38 PM »
i tried all 4 and when I hooked it up to my car and connected I used the same port on his.
« Reply #5 on: September 03 2015, 09:40:25 PM »
Prolly the 8.1. I noticed a lot of guys are having trouble getting it to work with PL. I have a separate laptop strictly for the track...with.. .wait for it...XP loaded on it. :)
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #6 on: September 03 2015, 09:42:15 PM »
I am running XP
« Reply #7 on: September 03 2015, 09:55:11 PM »
I am running XP
Your laptop doesn't work in his car. So what happens when you swap out your PL board on his ECM and try with your laptop? I just ran into this problem a couple weeks back in another guys car.
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #8 on: September 03 2015, 10:19:30 PM »
I really dont want to do that. the Pl must be working the scan tool has the extra data and is quicker, and when I turn the key off the light on the PL blinks.
« Reply #9 on: September 03 2015, 10:27:55 PM »
I swapped my PL board with his...and verified his PL board was junk.
Offline williambavila
« Reply #10 on: September 08 2015, 10:58:56 AM »
I finally got mine to work on windows 7 after a few issues. But I hve no clue how my buddy Steve got it to work.
« Reply #11 on: September 08 2015, 07:18:41 PM »
Keith got the drivers straightened out and all is good now
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #12 on: September 09 2015, 01:47:42 PM »
the CD that came with the new PL didnt have the drivers for the port, So I used my CD to load the drivers and had to dig thru my computer to manually initialize a port.
