I know. I was thinking that as soon as I tried putting the new sensor in and it touches the dampener. But that being said the old sensor is a few mm shorter and more so where broken.
If that was an original sensor, you'll be needing the bracket too. For some reason about 20 years ago the dimensions where changed and the 'upgraded' sensor needs a matching bracket.
Does anyone know if the plastic v's form an electrical loop?
Quote from: Forzfed on August 28 2015, 07:55:13 PMDoes anyone know if the plastic v's form an electrical loop? It is a Hall effect sensor, so it depends where the magnetic field(s) are/managed. According to this video both slots are active: https://www.youtube.com/watch?v=zWYJhcVXw_M
It would be pretty simple to test if you had another pigtail and could set up the power, ground, and signal (to a voltmeter) wires; and then just pass a length of metal through the slots to establish its sensitivity range up/down/in/out. Then modify.
