Author Topic: popping?  (Read 6772 times)
Re: popping?
« Reply #15 on: August 29 2015, 07:45:32 PM »
Give a thorough check of the up pipe hoses/clamps. I think Brian Harper here in town had the same problem...and going to T bolt clamps on the up pipe hoses solved it. Was drawing air in under boost...making it sputter/pop.
Re: popping?
« Reply #16 on: August 30 2015, 04:06:51 AM »
Under boost a leaky uppipe would vent, not suck.
Re: popping?
« Reply #17 on: August 30 2015, 07:36:24 AM »
Suck...vent... whatever. It'll pop. :) He was getting so pissed off with the car he was ready to part it out. :icon_eyes:
Now...here's a question for everyone. If the exhaust cam lobe was going south...could the air/fuel mixture get forced out the intake valve...cuz it can't get out the exhaust...maki ng it pop?
Re: popping?
« Reply #18 on: August 30 2015, 09:16:43 AM »
give us the o2s when it is popping
Re: popping?
« Reply #19 on: September 08 2015, 07:14:43 PM »
It would depend on what cylinder during the event. More than likely the exhaust heat and pressure would overcome the vacuum with the intake valve open, and to what extent the intake valve is open. Nightmaring back to the carburetor days, if we dealt with a car backfiring (popping) through the carb, (in this case I figure intake plenum?) it was a timing issue (dist. cap included) or a lean misfire. So let's throw a turbo at it and lean becomes a whole other issue, like Earl said: wastegate performance. Just a thought.
Re: popping?
« Reply #20 on: September 09 2015, 12:45:13 AM »
Venting .vs sucking is more than trivial in a MAF setup.    Sucking raw air will introduce unmetered oxygen into the mix with can result in a lean misfire.   Venting from a boost leak will just waste performance.
