Author Topic: Picked a new toy this weekend  (Read 104672 times)
Re: Picked a new toy this weekend
« Reply #90 on: December 20 2015, 07:10:51 PM »
Developed an oil leak from the timing cover. Cleaned it up, replaced the balancer seal. Still leaking. Cleaned again, fired it up and watched the leak develop just above the oil pan in front of the brass T for the oil pressure switch and guage and the timing cover.
Pulled the timing cover.... It's a bigger version of a turbo buick timing cover. Amazing similiarities between the AMC 360 and the Buick 3.8. Well looks like the gasket blew out on the upper hole which would be the pressure side.
It's apart... New timing chain going in as well as a new oil pan gasket.
« Reply #91 on: January 13 2016, 10:49:55 AM »
New timing chain installed and got a timing cover from Charlie as I broke a bolt off in the timing cover when removing the oil pump housing.  Got a mid-plate for the pump as well as new gears.  Primed the pump and got it all back together to find that I nicked one of the tubes on the radiator with the fan studs when I pulled it off with the timing cover.  Found that when I was filling the radiator up.  So the radiator is out and at the radiator shop to be soldered.  On the bright side of things, oil pressure is up and no oil leaks.
« Reply #92 on: January 13 2016, 01:50:24 PM »
That thing is gonna be a towing beast. Well not like the diesel pickup but way more cool imo.
Offline Be4u
« Reply #93 on: January 14 2016, 02:31:35 PM »
*like*
Save the bumper fillers!
Move to Canadia!
« Reply #94 on: January 15 2016, 10:20:58 AM »
*Like* is not an appropriate comment.  It is simply a four letter word and two asterisks that signifies that you don't care enough to dignify the OP's words appropriately.  It's just a space filler that is almost obscene in it's lack of appreciation.  Kinda like you, in other words.
« Reply #95 on: January 15 2016, 11:35:12 AM »
Got the Wagoneer back together yesterday evening. So far so good. Now we'll drive it a bit and see what else happens
« Reply #96 on: January 15 2016, 12:02:36 PM »
Nice time to enjoy the fruits of your labour
Offline Be4u
« Reply #97 on: January 15 2016, 02:33:22 PM »
Oh, like the billion FB users that hit that button everyday? No. I'm not fake.
Go crawl back under your pile of empty shells and let the grown folks be.
Move to Canadia!
« Reply #98 on: January 15 2016, 04:11:57 PM »
Grown? You mean over ripe...
« Reply #99 on: January 15 2016, 07:09:16 PM »
You guys are cracking me up
« Reply #100 on: January 15 2016, 07:17:33 PM »
And here I thought the goats were what was causing that smell. :rolleyes; Turns out it's two old farts. :rofl:
« Reply #101 on: January 15 2016, 08:47:17 PM »
And Charlie makes three::)
« Reply #102 on: January 15 2016, 10:40:08 PM »
Glad it is chuggin' along.
« Reply #103 on: January 15 2016, 11:34:29 PM »
And Charlie makes three: :)
I use beeno Steve. :icon_fU: Not to mention, I'm only 51. :rock:
Offline Be4u
« Reply #104 on: January 16 2016, 03:40:24 AM »
Only!!??!  :rofl:
Move to Canadia!
