front brakes
Pages:
2
Topic: front brakes (Read 6839 times)
gusszgs
Turbo Street Modified
PSI: 1
Limited quick brick
Re: front brakes
Reply #15 on:
September 07 2015, 10:16:35 AM »
Use a crows foot line wrench otherwise you'll probably strip it
Jim
1987 T Limited
Shimy87
PSI: 2
Re: front brakes
Reply #16 on:
September 24 2015, 02:16:14 PM »
Well got the new lines in and bled brakes. All is well, firm pedal, but I hate the inch and a half of pedal travel before the brakes hit. Is there a way to get rid of that? Was thinking of making a stop that would hit the pedal arm just above where the brakes apply and then adjust the brake light switch?
Any suggestions?
good2win22
Re: front brakes
Reply #17 on:
September 24 2015, 03:00:44 PM »
There's another switch that uses the brake pedal and it tells the computer that's it ok to lock and then unlock the torque converter when the brake pedal is depressed.
Shimy87
PSI: 2
Re: front brakes
Reply #18 on:
September 24 2015, 03:48:44 PM »
its not the same switch as the brake light? I don't remember a second switch from when I did the vacuum conversion?
good2win22
Re: front brakes
Reply #19 on:
September 24 2015, 04:19:19 PM »
I'm pretty sure there are two switches
earlbrown
PSI: 6
Re: front brakes
Reply #20 on:
September 24 2015, 09:39:46 PM »
I'm not 100, 100, 100% sure but I'm almost positive that brake and TCC are the same switch and cruise control is separate switch.
xpander343
Turbo Street Limited
Re: front brakes
Reply #21 on:
September 25 2015, 12:08:49 AM »
I bought a new brake light switch for my car recently and the cruise and light switch was the same piece.
If you check out rock-autos website you can look at the different switches.
But then they have a switch that says brake light switch and TCC without cruise, so
Did you end up reusing the old pedal or switching to a vacuum pedal when you did the swap?
last are rear shoes and drums adjusted up nice?
87 Regal Limited
Shimy87
PSI: 2
Re: front brakes
Reply #22 on:
September 25 2015, 11:04:06 AM »
Used vacuum pedal when switched, I adjusted the rear shoes up and that helped ALOT, took a lot of the free play out of pedal travel.......I can live with it as is now
Thanks a lot guys!
Pages:
2
front brakes
