Author Topic: Bullet proof my a...  (Read 6509 times)
« on: June 21 2015, 11:44:25 AM »
Damn ALKY pump....
Re: Bullet proof my a...
« Reply #1 on: June 21 2015, 01:55:34 PM »
Ouch!  That blows.... Pun intended.
« Reply #2 on: June 21 2015, 04:45:12 PM »
110 & constant PL monitor.
« Reply #3 on: June 21 2015, 05:02:18 PM »
Take a look at how much they are inside the chamber
« Reply #4 on: June 21 2015, 06:35:01 PM »
Kinda creates a hot spot that far in, doesn't it.
« Reply #5 on: June 21 2015, 06:51:36 PM »
My thoughts too even sitting on the block they hang inside and I'm only 20 over on the bore. Jason says it's fine I just wonder about a sharp edge heating up and encouragingly preignition.
« Reply #6 on: June 21 2015, 07:28:11 PM »
Larry...do you have a PL log for the run?
« Reply #7 on: June 21 2015, 07:47:21 PM »
I use tuner pro and a Genll translator to log data. It went lean WB correction went to max AFRs were 11.8
« Reply #8 on: June 21 2015, 07:49:17 PM »
What was the boost pressure?
« Reply #9 on: June 21 2015, 07:58:05 PM »
Got it home hit the test button no pump. Rapped the pump a couple times with a hammer away it went. It's already replaced going to throw some 9441s in it and see how it works.
« Reply #10 on: June 21 2015, 08:16:35 PM »
but it worked when you primed the pump with the test button before you made the run?
« Reply #11 on: June 21 2015, 08:19:37 PM »
Yes it appeared too
« Reply #12 on: June 21 2015, 08:23:19 PM »
The new pump works every time I tested it with the prime button and compressed air to check the controller.
« Reply #13 on: June 21 2015, 08:31:03 PM »
I wonder if one of those vampire knock sensors systems could kill things in time?
« Reply #14 on: June 21 2015, 09:05:56 PM »
Strange...I have found that pumps that have sat with alky in them don't like it after a few weeks, but, if the test function bogs the engine, then it should spray fine immediately after.  On the other hand, it may not spray a short time later.  I know Julio suggests rebuilding the pump every couple of years which I suspect is a good idea because there is no material that will completely resist methanol over a long period of time.
I don't thinh the hg overhang had anything to do with this one..but, my thinking ain't always right
