And I was expecting some sort of sex toy for the ladies.
Maybe a preformed oring that could be placed in position on the head followed by the cover would work
that he has yet to introduce to the marketAn aluminum shim that exactly fits the valve cover where the vc gasket should fit. Operative word, fit!!!!!!!!!!!!!On the engine head side of this shim would be affixed an 0-ring for sealing purposes.At the four mounting holes, in the shim, would be inserts which allows one to cinch the valve cover down til the inserts bottom out thus allowing equal tension all the way around.the smooth side of this "shim/gasket" would be glued to the valve cover gasket seating surface so that it is permanently installed to the cover and eliminate leaks and gasket shifting while trying to wrangle the cover into place
Let's just say I was thinking the toy would be in titanium. and the same mold can make Earl shaped candles too.
Quote from: earlbrown on June 23 2015, 04:26:14 AM Let's just say I was thinking the toy would be in titanium. and the same mold can make Earl shaped candles too.So they'd be short, dumpy, and horny? They wouldn't sell that well Earl.
As far as the other part.... Nobody said it had to be life sized and couldn't be scaled up.
