Author Topic: Cam Timing Question  (Read 2633 times)
Cam Timing Question
« on: June 18 2015, 07:59:53 PM »
How far retarded would a cam have to be before you'd see low compression numbers?
Re: Cam Timing Question
« Reply #1 on: June 18 2015, 08:21:47 PM »
It would depend on the cam Brad.
« Reply #2 on: June 18 2015, 08:45:54 PM »
214/214 from TA Performance-Flat tappet. Cam card says it's ground 6 degrees advanced. An Edelbrock adjustable timing chain was used set at zero. Compression clocked in at 150 on all cylinders.
« Reply #3 on: June 18 2015, 09:07:00 PM »
When they say it is ground advanced, that is reflected in the cam card numbers and should be installed straight up which should be the case when installed on zero assuming the gears are marked properly during manufacture.
If it's stock block with stock compression, 150 is probably pretty good because the cranking compression drops as we add duration in a general sense.  Advancing cam events six degrees should give a bit more cranking compression but it is still affected by the longer duration.  No free lunch.
« Reply #4 on: June 18 2015, 09:32:27 PM »
Steve...this is the engine that duplicated mine...with the exception of the cam/timing gears...but it ran low 13's. A roller cam is now in it...so I'll never be able to prove what I thot was wrong with it.
« Reply #5 on: June 18 2015, 09:44:01 PM »
I had this car at the track...and I was sitting in the passengers seat with the laptop and PL for a pass. I fell asleep waiting for the revs to come up on the tach on the gauge panel on PL.
« Reply #6 on: June 19 2015, 10:14:32 AM »
almost has to be the cam/gears...something wrong somewhere
