Author Topic: camvs compresion  (Read 5211 times)
Offline Tim Hensley
camvs compresion
« on: May 17 2015, 11:40:49 PM »
I ask it on the other form  thought id ask over here
I have two cams
FT 206-210 and a DLS 210-210
My new combo netted 8.2 to 1 compression ratio (Old was 9to 1)compression ratio is all that changed
Champion CNC Irons and intake
5857 BB S cover
2800 LU EA stage II
Both cams will get me to my 11.5 ET
Dose one cam work better with lower compression than the other
dose one have a flatter TQ curve
Both cams got me in the 11.s DLS with less boost 20lb  FT 25lb ,not  fair to compare  different heads with FT 206-210
DLS cam EX and LS is way different than FT EX and LS
DLS 210-210
Champion irons
Re: camvs compresion
« Reply #1 on: May 18 2015, 09:29:30 AM »
If you have the cam cards and some other info on the build you can figure out the dynamic compression ratio (DCR). Even though the 2 cams are close in specs duration @ .050 - they might have completely different valve events. If you can run them thru a DCR calc it might show which one will be more responsive off boost.
My guess is you probably wouldn't notice much difference between the 2 - but I haven't seen the cam cards either.
Steve will recommend trying to get the compression back to 9:1 - and I agree :)
« Reply #2 on: May 18 2015, 09:56:37 AM »
Yep....
side note, it takes the same hp to run 11.5 so the lower boost required is not all that meaningful.  It takes combustion heat to make hp so while one may require less boost, there are still the same number of air molecules in the combustion chamber so the stress on the engine is the same-in other words, there is no free lunch and the stress on the engine is the same.
« Reply #3 on: May 18 2015, 10:31:31 AM »
Cylinder pressure is cylinder pressure - most of the time more is better, until it's too much  :rofl:
Offline Tim Hensley
« Reply #4 on: May 18 2015, 12:31:14 PM »
there was a communication err on my part,I thought I said 9 to 1,but im not going to bash no one but myself,its built shipped and I have to live with it.
Ill run it through the DCR calc.Timing is different on the two cams ill get back with the #
DLS 210-210
Champion irons
Offline Tim Hensley
« Reply #5 on: May 18 2015, 12:47:29 PM »
This is FT cam
Static compression ratio of 8.2:1.
 Effective stroke is 3.20 inches.
 Your dynamic compression ratio is  7.72:1 .
 Your dynamic cranking pressure is 151.78 PSI.
 Your effective boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 25 PSI is 20.85 :1.
DLS cam
 Effective stroke is 3.15 inches.
 Your dynamic compression ratio is  7.61:1 .
 Your dynamic cranking pressure is 148.97 PSI.
 Your effective boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 25 PSI is 20.55 :1.
DLS 210-210
Champion irons
« Reply #6 on: May 18 2015, 05:20:18 PM »
probably will not be able to tell the difference but I would go with the first one just on scientific principles
« Reply #7 on: May 21 2015, 12:18:19 PM »
Tim can you play with the numbers and advance the cam(s) 2 and 4 degrees and see what the nets.
That might get it up some.
Steve how far can you push the DCR on pumpgas with cast iron headed LC2?
« Reply #8 on: May 21 2015, 04:27:06 PM »
Don't know...I run 9.2-1 static on both my cars.  One has the stock cam and the other one has a 210/210 roller but I don't have the cam card any more.  Both have iron heads.
Offline Tim Hensley
« Reply #9 on: May 23 2015, 01:08:29 AM »
Ill run the #
My DLS is +2 know ,I never see DLS cams advertise so Im trying to keep it low keyed
is your 210-210 a DLS ? I have my card and would send you a copy
DLS 210-210
Champion irons
« Reply #10 on: May 26 2015, 01:11:34 AM »
That's the reason cam manufacturers ''grind'' their cams advanced.    To make up for people killing the dynamic compression with intake lobes that are too fat.
When it comes to cams, bigger is hardly ever better.   You want just enough lobe to do the job and nothing more.
With us, we get to cheat. Compressed air is smaller than atmospheric air.    Our molecules can follow curves, flow through ports, and squirt past valves much easier with up to 3 times the pressure of the atmosphere helping out.
« Reply #11 on: May 29 2015, 08:54:46 PM »
Remember one thing. If you're not willing to put the boost to it...then the kid in the next lane with a Honda and a big fart can on it is gonna beat yer' ass. Won't matter what cam you have in it. I see so many guys spending wads of money on turbos and only running 20 lbs of boost. They won't run any higher boost pressure cuz they haven't got the balls to max the turbo out. Like Earl says...a bigger cam ain't always better. Time in my sig is with a flat tappet off the shelf 212/212 Comp Cams POS...and a little 62 turbo. :)
