Author Topic: Backing plate wheel cylinder repair  (Read 5532 times)
« on: April 17 2015, 05:48:33 PM »
So my wheel cylinder shifted on me did a few searches and heard about a clamp or retainer but no part number. Called my local parts store and got a "huh" from them as well. Did some more digging on line Part # GMB25851 brake drum wheel cylinder bracket called the store back they had 5 sitting on the shelf.....my first call they asked if I wanted the circle retaining clip....
Re: Backing plate wheel cylinder repair
« Reply #1 on: April 18 2015, 05:27:13 AM »
the hell is that?
« Reply #2 on: April 18 2015, 09:48:31 AM »
For wore out backing plates it holds the wheel cylinder in place.
« Reply #3 on: April 18 2015, 10:53:26 AM »
Good find I never heard of that before but if the Backing Plate is in Bad/Rusted condition wouldn't a new backing plate be in order & then maybe add that for extra insurance? It's your Brakes!   :O
« Reply #4 on: April 18 2015, 02:00:57 PM »
The ones I used looked nothing like that.
« Reply #5 on: April 18 2015, 04:16:24 PM »
My backing plate was not in bad shape other than the rotated wheel cylinder saved me pulling the axles and made it easier to install the retarded clip
« Reply #6 on: April 18 2015, 04:55:35 PM »
Granted it will avoid pulling the axle...
But our backing plates are the same as S10s and are all over the junkyard. I'm just trying to imagine how a backing plate can wear out. It's not exactly a wear item.
« Reply #7 on: April 18 2015, 05:29:44 PM »
Either my clip was weak the casting on the wheel cylinder was shit. The new wheel cylinder fit much tighter but for the sake of drilling 2 holes I installed the retainer. Spoke to a buddy who is a wrench he says it's common on gbodys and brake boosting only makes it worse
« Reply #8 on: April 18 2015, 06:35:53 PM »
That's because you live in Winterpeg!!  :rofl:
« Reply #9 on: April 18 2015, 06:37:30 PM »
I'm sure the E Brake launches don't help either!
Offline gusszgs
  • Limited quick brick
« Reply #10 on: April 19 2015, 09:17:20 AM »
Couldn't we just use an older "bolt in" style wheel cylinder,and just drill two holes to mount it??
Jim
1987 T Limited
