Author Topic: Low Impedance 83's And A Stock ECM  (Read 2793 times)
« on: April 12 2015, 04:21:14 PM »
Dan has the old skool 83's in his car. The so called modded ECM he purchased is NFG. Tossed in a stock ECM to get him up and running. Can he cruise the car around or should he wait till he gets a modded ECM. Kinda hoping he can hit the track with me.
Re: Low Impedance 83's And A Stock ECM
« Reply #1 on: April 12 2015, 08:26:53 PM »
I was under the impression that you could burn up the drivers running low impedance injectors with high impedance drivers.
« Reply #2 on: April 12 2015, 09:05:15 PM »
I think it will work if he takes it easy so it does not pull too much current
« Reply #3 on: April 13 2015, 01:01:55 AM »
Thanks Steve. He's old like me so he just cruises it around town. If he smokes it at the track...then no worries. He has an electric winch on his trailer. :)
« Reply #4 on: April 13 2015, 09:26:27 AM »
I have known a couple of guys that ran them a long time on a stock ecm
« Reply #5 on: April 13 2015, 11:13:32 AM »
I added a large computer fan to my modded ECM case to deal with the heat.  I keep a spare modded ECM in the trunk.  If the drivers from the modded ECM are serviceable Bob Bailey can transfer them over to another known-good stock ECM - that's what I did after one of mine went poof!
EDIT: There are also converter boxes from companies like AEM that will allow you to use low-Z injectors with a high-Z ECM.
« Reply #6 on: April 13 2015, 06:36:44 PM »
Mike...ya' got a link from the convertor from AEM?
« Reply #9 on: April 14 2015, 03:47:23 PM »
LOL... you can also do it with 6-6.5ohm resistors in-line on the power wire, as I understand it.
« Reply #10 on: April 14 2015, 08:07:37 PM »
Found something cheap that might be able to help you here. :rock:
http://www.superstreetonline.com/how-to/engine/htup-0804-honda-fuel-injectors-impedance-and-resistor-box/
Granted, this is for a 4 banger but there are 6 cylinder honda and other imports that may have a box on them as well.
