Author Topic: My 200 Trans Build Info  (Read 18242 times)
« Reply #15 on: April 11 2015, 05:52:08 PM »
Isn't that what they are for Brad?
Re: My 200 Trans Build Info
« Reply #16 on: April 11 2015, 07:19:09 PM »
No comment. :)
« Reply #17 on: April 12 2015, 08:56:04 AM »
That's why I bought mine. It got raced every chance I got when the trans was working. Which was hit n miss the first 3 or so years. We had a great time. Then I got married and had kids so my time was limited. Now I have it back together and am enjoying just driving it.
« Reply #18 on: April 18 2015, 08:34:16 PM »
Update...for anyone that's interested. :) The new transmission shifts are quicker and firmer...espec ially the 2-3 shift. I'll assume this is due to the billet direct clutch piston and dual feeding high gear. Was gonna get some PL shift data tomorrow at the track...but immediately upon test driving the new trans...the shifter assembly decided to take a dump. Swapping in another one tomorrow. I hate these cars...
« Reply #19 on: April 18 2015, 09:43:47 PM »
Nothing like a tranny that shifts right
« Reply #20 on: May 31 2015, 09:23:22 PM »
So my tranny was working pretty well my only complaint was the 2-3 shift. I had done the 2-3 control valve mod when I went thru the tranny prior to having it rebuilt by a local pro. (Sheared the band anchor burnt the drum)
He reversed all the mods I had done to the valve body decided to put my CK separator plate back on and mod the 2-3 control valve.
Whoo Hooo what a difference night and day 2-3 is crisp and quick not the slide in I was starting to get at WOT. When I originally did this mod I had a slight bind at low throttle wasn't kicking the band off fast enough not now 😃
« Reply #21 on: September 19 2015, 10:24:16 AM »
What 2nd servo are you using?
« Reply #22 on: September 19 2015, 10:56:11 AM »
Larry, I have a question too. :) What mod was done to the 2-3 control valve? Rich...maybe you could answer this. :)
« Reply #23 on: September 19 2015, 11:52:58 AM »
You install a 1/4 cup plug in the control valve bore than delete the spring install  the valve. It speeds up the 2-3 shift. I'll see if I can find my diagram it's in the CK shift kit instructions.
Page 9
http://www.ckperformance.com/Files/112573/200R4REVISEDSHIFTKITINSTRUCTIONSMAY192014OFFICE.pdf
« Last Edit: September 19 2015, 12:03:51 PM by larrym »
« Reply #24 on: September 19 2015, 12:06:22 PM »
Rich I missed your question its the Transgo billet servo.
