Author Topic: Guess The Weight Of My POS GN  (Read 10261 times)
« on: April 08 2015, 05:34:44 PM »
Been curious of what the POS weighs in at...so it's off to the weigh scales after Dan and I put the trans back in this weekend. Winner gets the fried clutches from my 200. :)
87 T Top
Full RJC pulleys
9.5" convertor
Balanced rotating assembly
Aluminum driveshaft
Aluminum rear drums
Aluminum rear bumper insert
Sound deadener removed
F Body rad swap
Air conditioning removed...heat er box retained.
Billet Specialties rims...9 lbs each
Billet lower control arms
Fiberglass front bumper
LT1 starter
No jack/spare tire
Re: Guess The Weight Of My POS GN
« Reply #1 on: April 08 2015, 08:08:38 PM »
You getting in? If so 3600#
If not 3450# (no I don't know you and haven't seen you so you might weigh more than 150#, I don't know)
Am I close? Mine is about (or used to be when I was a young man) 3600# with me in it.
« Reply #2 on: April 08 2015, 08:58:32 PM »
3462
Mines 3675 with me in it and half a tank of gas.
« Reply #3 on: April 08 2015, 09:44:52 PM »
3525lbs sans Scoob or the Bum.
Offline Joe Buick
« Reply #4 on: April 08 2015, 10:17:14 PM »
3650
JB RACING
« Reply #5 on: April 08 2015, 10:19:59 PM »
3580 with you in it
3380 without
« Reply #6 on: April 09 2015, 12:52:02 AM »
I'll be weighing it without me in it. I think there's a 1/4 tank of gas in it.
« Reply #7 on: April 09 2015, 09:37:58 AM »
3575 without you in it...that is in American pounds
« Reply #8 on: April 09 2015, 04:06:28 PM »
You should see my brain spinning making the calculation from American gallons to litres to get the octane level I want when I hit the track. I can't always get the same race gas octane from week to week...so I'm always having to bring the octane level up or down...and then adjust the high low timing on Erics chip to match it. I have Erics default race gas timing settings for every octane level. I'm gonna hoard a couple of pails of C16 for the fall. :)
Offline gusszgs
  • Limited quick brick
« Reply #9 on: April 10 2015, 08:28:48 PM »
1605 kgs w/o you
Jim
1987 T Limited
« Reply #10 on: April 10 2015, 09:08:43 PM »
1605 kgs w/o you
Jim...please tell me the weigh scales don't use kg's. :)
« Reply #11 on: April 10 2015, 09:30:00 PM »
Just multiply by 22000 and then divide by 10,000
« Reply #12 on: April 10 2015, 09:36:59 PM »
There's 1000 litres in a hectar...right? :)
« Reply #13 on: April 10 2015, 09:59:37 PM »
yep.....and 400 in an acre
« Reply #14 on: April 11 2015, 01:55:39 AM »
Yup mine scaled at 1670 kilos.
