Author Topic: Things Mechanics see..  (Read 63359 times)
Re: Things Mechanics see..
« Reply #30 on: June 23 2015, 06:58:39 PM »
« Reply #31 on: June 23 2015, 06:59:21 PM »
« Reply #32 on: June 23 2015, 07:01:14 PM »
« Reply #33 on: June 24 2015, 01:21:40 AM »
I need to do that to my S10 Blazer.   Damn heater core is right behind the radio and has a constant supply of hot coolant.
« Reply #34 on: June 24 2015, 08:08:02 AM »
Would a ball-valve be classier?
Offline xpander343
« Reply #35 on: June 24 2015, 09:25:14 AM »
damn that is so much nicer then using a pair of vice grips all summer
87 Regal Limited
« Reply #36 on: June 24 2015, 12:20:18 PM »
Exactly what I was thinking. Many years ago L Conley had a write up in GS Extra about a Quick Cool Down method for track days. It was basically remove thermostat, hook a garden hose size Plastic Tee to cut upper hose, add some heater hose with ball valve on the end that exits the hot water/steam under the frame. After a pass or two with the Engine at Idle, open ball valve, steam shoots out, remove rad cap & pour in cool water & the engine instantly cools down. Fill rad & as water cools down close Ball valve & top up rad. I did it a few times & it worked well but the engine better be running!! Man people used to look from a distance & scratch their heads!!   :O
My home made Up Pipe Cool Box made of Copper looked a damn Still but at least I was creative! Still have that copper bundle in my shop!  :rock:
« Reply #37 on: June 24 2015, 03:44:56 PM »
Sounds pretty much like the Prestone flush fittings they used to ship with antifreeze?
« Reply #38 on: June 24 2015, 05:48:51 PM »
Ya more or less but the 1/2 turn ball fitting was a few $$ more.  :)
The Cold Box had Tech guys ask a lot of questions at Cayuga but London they just asked if I had a helmet & good to go! Those were Fun times back in 90-92 & that's when Paul Beal (twin 86 GN's) was out with his Dad.
« Last Edit: June 24 2015, 05:54:01 PM by Just a Six? »
« Reply #39 on: June 24 2015, 07:18:38 PM »
If I was in charge there would only be ball valves
and military connectors
« Reply #40 on: June 24 2015, 09:09:47 PM »
Damn Straight!!  :player:
« Reply #41 on: June 25 2015, 06:23:02 AM »
What's a military connection?
« Reply #42 on: June 25 2015, 08:42:06 AM »
« Reply #43 on: July 06 2015, 10:47:02 PM »
Offline gordyzx9r
  • The Sultan of Swank
« Reply #44 on: July 16 2015, 12:55:26 PM »
That was probably a post office vehicle...most of the post offices around here use private vehicles to deliver the mail.
EDIT:  In regards to the pic on page 2 with the two steering wheels.
