washer. weld. nut. weld. extract.Basically this: https://www.youtube.com/watch?v=aRrz-cphBY4But using the washer first gives you more surface area to weld against, especially when you weld the outside of the nut to the washer face, and then the stud to the inside of the nut.
Quote from: motorhead on March 12 2015, 03:00:41 PMwasher. weld. nut. weld. extract.Basically this: https://www.youtube.com/watch?v=aRrz-cphBY4But using the washer first gives you more surface area to weld against, especially when you weld the outside of the nut to the washer face, and then the stud to the inside of the nut.And that is exactly how I had it taken off this morning...Got everything on without a hiccup the second time around. Hit the pre-luber then started her up. Only got to idle her a bit before the rain clouds started rolling in so I didn't get a chance to take it out but there are no oil leaks (yet).
Return line, easy...matched right up.The exhaust was easy...matched right up.Putting the 4 bolts thru the DP and mother fucker...
Torque really isn't all that important in that area. It' not like you're deflecting anything with clamping force. All you're doing is clamping the two flanges tight enough so that the thing layer of RTV can do it's job.It's way more important to use anti-seeze on exhaust bolts, ESP anything touching the hot side of a turbo.
