Author Topic: Fuel pump?  (Read 18506 times)
Re: Fuel pump?
« Reply #45 on: May 22 2015, 04:32:27 PM »
Yeah, let me know how it works Larry.  I'm stilling waiting for the guys to get back to me with prices.  Is there any wiring modifications that have to be done for it to work?  Besides the hotwire kit of course.
Re: Fuel pump?
« Reply #46 on: May 22 2015, 04:46:28 PM »
I will post some pics of the installation.
Re: Fuel pump?
« Reply #47 on: May 22 2015, 05:28:15 PM »
Ok, thanks Larry! :cheers:
Re: Fuel pump?
« Reply #48 on: May 23 2015, 03:10:35 PM »
Just ordered the AEM 320 today.
Fuel pump?
« Reply #49 on: May 23 2015, 10:54:17 PM »
Went in pretty easy had to drop my base fuel pressure about 5psi after the install to get it to 43 psi.
Fuel pump?
« Reply #50 on: May 23 2015, 11:00:31 PM »
I was able to reuse the plug from the walbro 340m AEM supplies a little rubber foot that the sock and pump sit on worked pretty slick and fit in the hanger well.
Pumps quiet compared to the walbro.
Re: Fuel pump?
« Reply #51 on: May 24 2015, 03:10:44 PM »
Right on!  So, no bigger return line is needed?
Fuel pump?
« Reply #52 on: May 24 2015, 03:23:41 PM »
Not for me.
Re: Fuel pump?
« Reply #53 on: May 24 2015, 03:59:55 PM »
Good to know!  I figure with the 4.1 I should be fine too, hopefully. :cheers:
Re: Fuel pump?
« Reply #54 on: June 02 2015, 09:20:20 PM »
Put the pump in tonight.  Wow, what a difference!  The car pulls way way better.  The XP Armstrong pump is crap in comparison.  My car always liked more fuel.  I tried to buy a double pumper setup but Red talked me into an XP which was barely better than my normal Walbro 340.
Fuel pump?
« Reply #55 on: June 02 2015, 09:28:14 PM »
Pretty quiet too
Re: Fuel pump?
« Reply #56 on: June 03 2015, 10:48:22 AM »
I did have to turn the pressure down and I got rid of the thin wires. Used the different end on the hanger the other one had a gap and didn't sit flat in the hanger.
Re: Fuel pump?
« Reply #57 on: June 03 2015, 01:56:42 PM »
What was the flowrate of the original EP-381 pump?
