Author Topic: Barn motor ideas...  (Read 46989 times)
Re: Barn motor ideas...
« Reply #30 on: March 01 2015, 02:29:48 PM »
Charlie,
I was hoping to pick up that cam from you today.  Gimme a shout!
« Reply #31 on: March 04 2015, 01:08:25 PM »
Hey fellas...  Looking to hear from ya'll about timing chain recommendation s for a roller cam.
« Reply #32 on: March 04 2015, 02:06:21 PM »
Apparently the TA chain is the go to piece from what I hear.
I have a ProGear in mine its been good so far little noisy.
« Reply #33 on: March 04 2015, 02:25:04 PM »
Didn't someone just have one of theirs break with easy driving?
« Reply #34 on: March 04 2015, 02:45:56 PM »
I was mistaken. It was a weber chain that broke
« Reply #35 on: March 04 2015, 03:35:18 PM »
Lotsa roller chains will actually stretch faster than a stock single chain so research can be useful if in doubt of brand.  I think RollMaster has good rep and offers a pre-stretched chain in at least some versions.
An old trick that seemed to help was to submerge the new chain in oil that was heated to about 200 degrees for about an hour.  A moly additive in the oil was suggested.  This seems to have increased the life of the chain substantially.  this probably only works on chevies so....:)
« Reply #36 on: March 04 2015, 04:44:18 PM »
Ruh Roh I got my chain from Webber........ ..
« Reply #37 on: March 04 2015, 08:01:29 PM »
It broke on Keith's car but we don't know if it was the chain's fault, or something else for sure.  Car has run okay since the engine was rebuilt
« Reply #38 on: March 04 2015, 09:15:34 PM »
An old trick that seemed to help was to submerge the new chain in oil that was heated to about 200 degrees for about an hour.  A moly additive in the oil was suggested.  This seems to have increased the life of the chain substantially.  this probably only works on chevies so.... :)
Your right about them stretching.  When I was running that 429, I would change the timing set every spring.
I was curious if these sets would stretch as quickly since we are turning two less sets of springs
« Reply #39 on: March 04 2015, 10:07:26 PM »
http://forums.hotrod.com/hot-rod/70/1292542/pit-stop/timing-chain-slack-test/
Quote
According to Isky..
".. An excessively stretched chain can retard cam timing, as much as four cam degrees, because of the slack in the links. Also, even though most of the valve timing figures in this catalog are listed at split overlap, most of our camshafts are ground from one to two cam degrees advanced to allow for eventual stretch in the timing chain..."
Just means that it will makes more power up top later on down the road. ;)
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #40 on: March 05 2015, 09:13:24 AM »
IT was my chain that had broke, it was the one from Weber and I never found the reason that the chain broke other than it just broke. I did go with the Roll Master set on the rebuild BUT I had to ream the holes on the cam gear to get it to line up.
Barn motor ideas...
« Reply #41 on: March 05 2015, 12:23:15 PM »
What type of cam and what sort of spring pressure?
« Reply #42 on: March 05 2015, 01:56:12 PM »
From yall's signature looks like the same cam. Springs?
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #43 on: March 05 2015, 02:06:31 PM »
I believe that mine are the PAC -1201-12 from Weber.
 weberpowerprod ucts.com/3-8l-turbo-buick-v6-valve-springs-p/pac-1201-12.htm
« Reply #44 on: March 05 2015, 04:34:49 PM »
yes sir same set up eeeep I guess I'm looking at a chain....
