won't start after front seal repair
Pages:
5
6
7
8
Topic: won't start after front seal repair (Read 28759 times)
TurboCajun
Keith Theriot
Turbo Street Modified
PSI: 1
6 Packed
Re: won't start after front seal repair
Reply #90 on:
March 03 2015, 12:35:30 PM »
it is how I learned, with the help of you guys
Reply #91 on:
March 03 2015, 12:41:58 PM »
learning is a never ending ordeal
poppy1440
Bone Stock
Reply #92 on:
March 03 2015, 11:10:31 PM »
I'm leaning more and more each time I have an issue with this car.
but believe it or not its therapeutic to me.
I doubt I have put 1,000 miles on my car in the last 5 years because my life is so hectic. When I do get a break I spend it with the family. but now both of my sons have part time jobs and they are hardly ever home and my wife is addicted to television so I go out to my shop and take something apart and 9 times out of 10 it doesn't work properly when I put it back together and thats when the fun begins.
Mr Steve if they think this was tough they should take a look at this thread.
http://www.ihadav8.com/forum/index.php?topic=3164.msg49568#msg49568
86 gn. Champion irons, roller cam,stock location stretch intercooler, 3" exhaust," DP, scan master, red Armstrong pump hot wired, 60 lbs injectors, Razors' alky kit, 6265, 6.0 chip, powerlogger, plx-afr, mt 275/50r15 et street
Reply #93 on:
March 04 2015, 11:04:25 AM »
Yep, you firmly implanted the need to check for egr leaks in that thread!
poppy1440
Bone Stock
Reply #94 on:
March 14 2015, 08:55:13 PM »
Just for information the car is still leaking and it seems to be coming from front seal area again. I think Im just gonna live it.
Question:
what should oil pressure be at idle and 45 mph cruising.
Mine is 20 and 38-40
poppy1440
Bone Stock
Reply #95 on:
March 14 2015, 09:32:26 PM »
Its really around 15 @ idle
gnonyx
Boost n00b
Reply #96 on:
March 14 2015, 09:55:50 PM »
Not to insult you, but are you sure it's oil? or is it water?
What type of front seal did you used?
poppy1440
Bone Stock
Reply #97 on:
March 15 2015, 12:20:57 AM »
Neoprene seal.
I'm not insulted but im 100% sure it's the oil pressure guage.
The car runs great but it just seems a little low
earlbrown
PSI: 6
Reply #98 on:
March 15 2015, 01:20:08 AM »
Clean the living shit out of the front of the engine with brake parts cleaner.
Go around the block then throw some baby powder where you think it's leaking. Whatever is wet will light up like the forth of July.
TexasT
Legend in my own mind
PSI: 1
So, This black car is fast?
Reply #99 on:
March 15 2015, 09:44:15 AM »
When "throwing" baby power I use an old oil field water hauler trick. I have an empty mustard squeeze bottle with the twist to open top. I use a funnel to pour the baby power into the mustard bottle(I must be cleaned out and dry).
Then you can "squirt" the baby powder where you want it.
http://www.bloomberg.com/ss/10/10/1007_bestselling_condiments/image/08_frenchs.jpg
I usually cut the top off the baby powder as it takes too long to get it out other wise.
poppy1440
Bone Stock
Reply #100 on:
March 15 2015, 11:44:05 AM »
Thanks
I'll give that a try.
Reply #101 on:
March 15 2015, 02:30:45 PM »
Pit some pipe dope on the threads before screwing the fitting in
earlbrown
PSI: 6
Reply #102 on:
March 16 2015, 02:55:55 AM »
Did you reinstall the oil slinger in front of the bottom timing chain gear?
And is this a GM timing cover? And are both the locating dowel pins still in the block?
poppy1440
Bone Stock
Reply #103 on:
March 16 2015, 03:12:30 PM »
I don't recall installing anything other than the gasket.
It's one of your covers Mr. Brown.
Im gonna try to see what the oil slinger looks like.
It looks like the oil is gathering right below the front seal on the little beveled lip.
larrym
PSI: 1
Reply #104 on:
March 16 2015, 03:17:43 PM »
Did miss the hidden bolt on the cover?
Pages:
5
6
7
8
