ok I checked a few more things.1. I reset the cam sensor. I made sure it was at 25 atdc and then used the cam sensor tool to reset it.2. I used a playing card and cut it long ways about a 1/4 inch wide and placed it on each side of re-luctor wheel inside the crank sensor. The reluctor wheel goes freely thru the sensor with very little if any contact.3. I checked all the fuses.4. The fuel pump is priming to 40psi.5. Key on I have over 11 volts on the green wire that goes to crank sensor. unpluggedOne thing I did not mention is that I just got my ecm back from eric at turbo tweak who made some repairs to my power logger.I thought I would throw that in because I stated earlier that the only thing I had done was change front seal.But he assured me that all is well with the ecm and chip. Next I plan to text the crank sensor itself.
