Author Topic: won't start after front seal repair  (Read 29502 times)
Offline poppy1440
Re: won't start after front seal repair
« Reply #105 on: March 16 2015, 03:42:07 PM »
I just pulled a picture of the oil Salinger.
I didn't remove it nor did I see it.
I wonder if it was put on when the motor was rebuilt a couple of years ago.
86 gn. Champion irons, roller cam,stock location stretch intercooler, 3" exhaust," DP, scan master, red Armstrong  pump hot wired,  60 lbs injectors, Razors' alky kit, 6265, 6.0 chip, powerlogger, plx-afr, mt 275/50r15 et street
« Reply #106 on: March 16 2015, 04:28:22 PM »
 I've ready posts saying that not having one can cause front seal leaks.
Caveat: I have no first hand experience with that and I've always had the slinger in place.
« Reply #107 on: March 16 2015, 10:23:18 PM »
definitely allows oil to be thrown straight against the seal/crank interface
« Reply #108 on: March 17 2015, 01:45:46 AM »
seal/hub   :D
Offline gnonyx
« Reply #109 on: March 17 2015, 07:39:36 AM »
Was the oil leak there when the motor was rebuilt?
It might be possible to remove the side plate on the timing cover to see if you do have the Slinger in place
As you can see where the Slinger is located, and if you can't see it or feel it's there, then you might have to remove the timing cover, and Balancer in order to replace the Slinger back home.
« Reply #110 on: March 17 2015, 02:25:15 PM »
Offline poppy1440
« Reply #111 on: March 18 2015, 12:50:36 AM »
When I think back,  I feel you might be right about the oil slinger probably wasn't put back on when my engine was rebuilt a few years back because it has been leaking for as long as I can remember
