Author Topic: 11.5 time bomb  (Read 9623 times)
Re: 11.5 time bomb
« Reply #15 on: February 15 2015, 06:15:36 PM »
Post pic's of the rod bearing.
I'd think detention would take out the rod bearings 1st. That looks like either the caps are walking or the clearance is to tight on the middle caps.
Re: 11.5 time bomb
« Reply #16 on: February 15 2015, 06:50:42 PM »
One cannot tell if the caps are fitted properly by trying to move them by hand.  The combustion process places hundreds, if not thousands, of pounds more force on them.
I agree, Jeremy, that detonation will take out the rods first and probably break the crank before it destroys the mains.  I think the machine shop gets the blame on this one.  Of course, they will assure you that they were perfect but we used to see a lot of these before we learned that the factory used a broaching cutter on the block and the aftermarket  caps would not fit properly without reworking as Brad described.
Re: 11.5 time bomb
« Reply #17 on: February 15 2015, 11:17:41 PM »
Most guys aren't going fast enuf to require steel main caps...girdle etc. Nothing wrong with going that route...but you'd better find a machinist that knows his shit...or you'll end up with all kinds of issues.
Offline Tim Hensley
Re: 11.5 time bomb
« Reply #18 on: February 16 2015, 01:26:32 AM »
thanks for all the post,I had time today to take these pic #1 and #4 all look the same but #3 has some slight
damage.My next block will be done by someone that know his $#!t from the mainland.I put it together with .002
DLS 210-210
Champion irons
Offline 278CIKILLER
Re: 11.5 time bomb
« Reply #19 on: February 16 2015, 10:06:35 AM »
Tim how much will it cost you to send it to the mainland and have it done again?
Offline Tim Hensley
Re: 11.5 time bomb
« Reply #20 on: February 16 2015, 11:14:08 AM »
$450 -500 both ways and it will weigh more coming back
DLS 210-210
Champion irons
Offline Tim Hensley
Re: 11.5 time bomb
« Reply #21 on: February 16 2015, 11:15:34 AM »
450-500 each way not round trip
DLS 210-210
Champion irons
Offline 278CIKILLER
Re: 11.5 time bomb
« Reply #22 on: February 16 2015, 11:30:57 AM »
Plus the build?
Re: 11.5 time bomb
« Reply #23 on: February 16 2015, 01:05:16 PM »
Looks like that second pic might have hammered the bearing a little. Looks like the trash from the mains went thru them too.
I'd talk with a reputable builder - but it might not be cost effective to continue with your block and caps. It they screwed up the line bore/hone things will just snow ball.
Re: 11.5 time bomb
« Reply #24 on: February 16 2015, 06:12:12 PM »
The problem with align honing is that the cam and crank are brought closer together. Align bore is far superior...in that you can take most of the 'meat' from the cap...and a minimum from the block.
Offline Tim Hensley
Re: 11.5 time bomb
« Reply #25 on: February 16 2015, 08:37:18 PM »
Yes getting a different block,wish I could find  a new block and a TA  is way out of my needs , just a bad pic no hammering just trash.
DLS 210-210
Champion irons
Offline 278CIKILLER
Re: 11.5 time bomb
« Reply #26 on: February 16 2015, 08:50:11 PM »
I have a 4.1 block that was purchase in B/G and the build didn't happen comes with rods and piston. $500.00 plus the ride.
Offline Tim Hensley
Re: 11.5 time bomb
« Reply #27 on: February 17 2015, 11:56:00 PM »
Arizona gn came through with a 109 and will build me short block ,i chose not to do a stroker
DLS 210-210
Champion irons
