Author Topic: drain back  (Read 2338 times)
Offline Tim Hensley
drain back
« on: February 05 2015, 11:09:48 PM »
my NA block i need to tap Is it 1/2 pipe or 3/8 pipe
DLS 210-210
Champion irons
Offline Tim Hensley
Re: drain back
« Reply #1 on: February 05 2015, 11:15:24 PM »
And should I tap the lifter oil feed lines or stay with the expansion plugs?
DLS 210-210
Champion irons
Re: drain back
« Reply #2 on: February 06 2015, 03:45:10 AM »
I/2" NPT on the oil drain. and I like tapping the galley plugs...    BUT be careful on the passenger side with the tap, don't go as deep as much as you think you need to.
After going about 1/2 as much as you think you need to, test fit the plug.  If it goes too deep, you'll cut off the oil supply to everything but the turbo (and pressure gauge if you have one)
Offline Tim Hensley
Re: drain back
« Reply #3 on: February 07 2015, 04:47:26 PM »
Thanks
DLS 210-210
Champion irons
