Author Topic: Flat tappet lifters  (Read 17095 times)
Re: Flat tappet lifters
« Reply #15 on: February 04 2015, 05:27:38 PM »
Those stockers were tired in 1987
Especially after it sat for a decade with a blown hg.
« Reply #16 on: February 04 2015, 05:46:34 PM »
Guys...if you ever overboost an engine to the point of spitting the head gaskets out of it...swap in a new set of springs while the heads are off. If you don't...then I promise you your car will fall on its face in high gear...and prolly against your biggest rival in a grudge race. Don't make the same mistake I did. I ended up having to wait 2 years to get up against this guy again to redeem myself.
Flat tappet lifters
« Reply #17 on: February 04 2015, 05:55:25 PM »
That Brad is reason enough to swap the springs. Who cares about the head gasket.
