Scoob! If I recall in your engines the Bearings always look evenly worn. I can always save them for you next time.
I learned early on to get off the loud pedal if I see a hint of KR....cuz it`ll turn bearings into tinfoil in a heartbeat. I have Joe magnaflux the block, rods and crank...and the crank and rods are checked for straight. If an align hone is required...the
n it`s done...along with the deck being checked for straight. The big ends on the rods are also checked for size...and the rotating assembly balanced. I leave the bearing clearances and ring gaps up to Joe. He does the oiling mods to the cover and sets the oil pump clearances.
Getting back on track. Larry, it`s hard to say if the clearances were correct in that engine...or how much KR it saw.
