The Bastard Child Buick Board
maf ?
Topic: maf ? (Read 2767 times)
shmed
Turbo Street Limited
maf ?
January 25 2015, 03:12:04 PM »
hi just about to order a maf from full throttle an had a question
they list a 3.5 inch maf an a 85 mm maf
my turbo is 4 inch inlet so would the 3.5 be the better choice for me?
thanks
Scoobum
Re: maf ?
January 25 2015, 03:18:52 PM »
I have the 4" setup on my car with the 85 MM Z06 MAF...which requires the 3 to 5 pin adaptor...avai
lable from FT. You'll also have to use a different base setting in the Translator...c
an't remember which one tho. The Z06 MAF is actually 3.75" if memory serves. I ordered the proper adaptor hose from one of the speed shops up here. Think it was Karbelt.
motorhead
PSI: 4
Re: maf ?
January 25 2015, 03:26:53 PM »
Get a 4" MAF tube and C6 ZO6 sensor. I believe that Full Throttle sells it... here is my build for the TBSS:
http://www.tbssowners.com/forums/showthread.php?t=133002
P/Ns:
http://www.tbssowners.com/forums/showthread.php?t=95071
I got everything off Amazon or Summit racing, the aluminum piping and silicone couplers came off eBay.
Don't over spend.
motorhead
PSI: 4
Re: maf ?
January 25 2015, 03:31:32 PM »
Here is their thread from 2007:
http://www.turbobuicks.com/forums/buick-v6-turbo-tech/61277-new-4-maf-pipe-built-maf-sensor.html
earlbrown
PSI: 6
Re: maf ?
January 26 2015, 04:18:03 AM »
What kind of MAF pipe are you running? That'll kinda dictate what MAF, filter, etc... you can run.
With a 4" inlet on the turbo are you necking down to 3" or 3.5"?
shmed
Re: maf ?
Reply #5 on:
January 26 2015, 06:27:32 PM »
hi earl i have a 4 inch pipe from rjc
i dont wanna neck down if i don't have to
i do also have the translator regular one i guess.
maf ?
