Author Topic: Oil return line  (Read 84761 times)
Re: Oil return line
« Reply #15 on: January 30 2015, 01:12:47 PM »
thanks!
Re: Oil return line
« Reply #16 on: January 30 2015, 05:42:30 PM »
okay...added it...
http://www.vortexbuicks-etc.com/turbo_drain_hose.htm
You did a really nice job, Larry!
Oil return line
« Reply #17 on: January 30 2015, 05:48:10 PM »
Awesome thanks Steve 😋 glad I can maybe help someone down the road.
Re: Oil return line
« Reply #18 on: January 31 2015, 10:35:28 AM »
Looking real good. I spec'ed it out and came up with $118.87 shipped with American money. Upside ill have 2'10" of extra hose as it comes in 3' sections.
Nice Work!
Oil return line
« Reply #19 on: January 31 2015, 12:12:08 PM »
I picked up all my parts at Lordco I get a decent discount but I'm sure all said and done I'm into for $100.00
Re: Oil return line
« Reply #20 on: January 31 2015, 12:12:45 PM »
I like it!
Re: Oil return line
« Reply #21 on: January 31 2015, 01:49:43 PM »
Larry...thanks so much for the pics and part numbers. If I ever get in a jamb then my guy at the speed shop can bail me out. :)
Re: Oil return line
« Reply #22 on: February 06 2015, 04:27:18 AM »
Oil return line
« Reply #23 on: February 06 2015, 12:20:29 PM »
After seeing the size of the -10 I would not go any smaller. I even ran a 1/2 drill thru the vibrant fitting because I thought it looked small.
Re: Oil return line
« Reply #24 on: February 06 2015, 03:28:03 PM »
Odd. -10 is 5/8".  A 1/2" drill shouldn't have made any chips.  -8 is supposed to 1/2".
I made mine out of -12 and dumped it straight into the pan but I can't recall the exact ID of those fittings.
« Last Edit: February 06 2015, 03:32:22 PM by earlbrown »
Re: Oil return line
« Reply #25 on: February 06 2015, 05:54:55 PM »
It was just the Vibrant fitting it did not do much but did open it up a little, with the OD being 5/8 it brings the ID close to half inch with the wall of the hose plus the fitting being pressed into it, these things are mass produced who knows what happens with the tooling after they make a few thousand.
I was just being cautious I wanted to ensure there was no restrictions at the narrowest point, last thing I wanted was oil collecting and my turbo seals failing prematurely.
Re: Oil return line
« Reply #26 on: February 20 2015, 01:23:06 PM »
well that did not work as planned.......
Apparently Cottons has a repop available should have listened to Brad stock Junk always works best.
I installed my stock turbo to confirm the results.
So my question is how pouched is the turbo?
It still feels tight no oil on the inlet side there is a metal oil ring on the turbine side works like a piston ring from what I have researched  and all the locals say they will not touch a Turbonetics turbo.
A buddy is going to lend me his stock line for the week end.
Re: Oil return line
« Reply #27 on: February 20 2015, 01:37:17 PM »
lost me.  What did not work?  The oil return line?
Oil return line
« Reply #28 on: February 20 2015, 01:45:00 PM »
That's my assumption at this point
Oil return line
« Reply #29 on: February 20 2015, 02:15:12 PM »
I am borrowing a stock return line for the weekend and will let you know what happens.
