The Bastard Child Buick Board
Knowledge Base Articles, Submissions, and Comments
Oil return line
2
3
Topic: Oil return line (Read 29744 times)
larrym
PSI: 1
Oil return line
January 20 2015, 02:40:24 PM »
So while re installing my return line in the new bock I cracked it.... Glad I found it before I installed the motor.
Here are a list of parts I ordered From Russell to make a new line I know there are other vendors and probably cheaper ways but in Canada with freight and duty to deal with I can do this overnight for $80.00 Canadian.
http://www.summitracing.com/int/parts/rus-697090
Will not work
Used Vibrant part# 2849
http://www.summitracing.com/int/parts/rus-660503
http://www.summitracing.com/int/parts/rus-610113
X2
http://www.summitracing.com/int/parts/rus-632153
I'll take some pictures once its all together and mocked up on the turbo.
Last Edit: January 24 2015, 02:39:44 PM by larrym
TexasT
Legend in my own mind
PSI: 1
So, This black car is fast?
Re: Oil return line
January 20 2015, 07:33:32 PM »
Looking forward to pix. I had a really nice and generous individual that sent me a stock one out of the goodness of their heart. I thought it only right to use it. I hope yours turns out well. I also have a braided flex piece with male threads on each end I bought somewhere along the way. Not sure how it hooks to the turbo. But I think it screws into the block. But it is straight so I'm not sure how it would work. Funny how things are bought/sold with no way they would work without major mods or fab.
Scoobum
Re: Oil return line
January 20 2015, 11:22:00 PM »
Exactly why I stay with stock junk. It was engineered to fit.
larrym
PSI: 1
Oil return line
January 21 2015, 11:43:11 AM »
Yeah I would have used the stocker but it was junk.....
Scoobum
Re: Oil return line
January 21 2015, 04:47:57 PM »
Make sure the ID is the same as the stocker.
larrym
PSI: 1
Oil return line
Reply #5 on:
January 21 2015, 07:22:53 PM »
Thanks Brad from what I have researched -10 is biggest concern after that is to maintain as straight a shot with no 90 degree bends or low spots for oil to collect
larrym
PSI: 1
Re: Oil return line
Reply #6 on:
January 24 2015, 02:36:26 PM »
The flange will not fit.
Vibrant part# 2849 will I hope the size appears right.
http://vibrantperformance.com/2012_catalogue/2012_catalogue_pg38.pdf
Would have been overnight but the performance warehouse was flooded....
Thats what I get for living in a rain forest.
larrym
PSI: 1
Re: Oil return line
Reply #7 on:
January 24 2015, 04:51:40 PM »
here is the line mocked up just need the turbo flange its all fittings with 2" of hose.
larrym
PSI: 1
Re: Oil return line
Reply #8 on:
January 27 2015, 11:17:44 PM »
So finally got it all together made a couple changes, decided a -10AN to 1/2 NPT 45 degree fitting at the block with a straight hose end would fit better.
Worked well good slope and looks clean.
So parts used.
Vibrant # 2849 turbo drain adapter
Russell fittings
660973 -10AN to 1/2 NPT 45degree
610043 straight -10AN hose end
610113 45 degree -10 AN hose end
3" of hose
Re: Oil return line
Reply #9 on:
January 28 2015, 01:30:55 PM »
If you can take a couple bit better pics so the orientation is more clear, I would put this on my site...might help someone else down the road. Looks really nice
larrym
PSI: 1
Re: Oil return line
Reply #10 on:
January 28 2015, 10:56:20 PM »
Thanks for the compliment Steve, figured I would listed the parts and maybe save some one some time down the road.
I know a search has saved me buying things I couldn't use or didn't fit.
larrym
PSI: 1
Re: Oil return line
Reply #11 on:
January 28 2015, 11:01:55 PM »
Re: Oil return line
Reply #12 on:
January 30 2015, 11:46:15 AM »
Larry, above you said a 45 deg fitting into the block...but, it looks straight to me in the last pictures. I see a 45 deg fitting at the turbo end
In your parts list, you show two 45's
Is it just the camera angle that makes it look straight at the block?
larrym
PSI: 1
Re: Oil return line
Reply #13 on:
January 30 2015, 12:51:32 PM »
double posted....
Last Edit: January 30 2015, 01:05:25 PM by larrym
larrym
PSI: 1
Re: Oil return line
Reply #14 on:
January 30 2015, 12:52:38 PM »
Pa
rt of the problem is the color and the angle black in black.
This is threaded into the block its clocked to around 10.5 oclock Russell 660973
I found the straight fitting and 45 hose end moved the line out to far with not as much slope.
This was attached to this fitting 610043
the hose than 610113
I attached this to the turbo Vibrant 2849
No gasket was provided but I have faith the right stuff is the right stuff to use that was my thread sealant at the block as well.
I was careful to ensure everything had slope so oil will not collect, my turbo is a BB unit with a feed restricter over all I'm happy with the install.
Last Edit: January 30 2015, 01:00:14 PM by larrym
2
3
Oil return line
