Found a coolant leak. Turned out to be from the weep hole at the bottom of the water pump. Had another water pump from the barn motor but then decided to have a look at the timing chain. Factory gears and chain were installed. Found a deal from Cloyes on their true street roller and figured on replacing the timing set while I was in there as well as cleaning things up a bit. Also installed a roller thrust button. Was a bit concerned with setting the cam sensor with a volt meter but all went well and she's back up and running.
Also found a deal on some flow matched 42's with a 5.7 street chip without alky. Since the ghost will be a driver till the barn motor is done, I snatched them up. Should be here Friday.
