Author Topic: Data log 1/10/15  (Read 3435 times)
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
Data log 1/10/15
« on: January 10 2015, 06:48:12 PM »
Finally figured the problem with the boost, operator error, just a short hit , boost is up and down but i am running on only the waste gate actuator rod. O2s are low but no knock
Offline TWIN86GNS
  • My car is almost ready!!!!
Re: Data log 1/10/15
« Reply #1 on: January 11 2015, 05:21:12 AM »
Must be nice to be able to test and tune at this time of year!!!  I am going out fishing soon and I don't have a boat, that is right, going out on the ice to drill some holes and catch some fish.   :rock:
Paul Beal
beal_paul@yahoo.ca
« Reply #2 on: January 11 2015, 05:37:30 AM »
File looks fine.
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #3 on: January 11 2015, 01:27:27 PM »
add a couple more files, two rounds on the waste gate arm and got a spike at 26 and 27, boost was a lil more steady on the second run with the dump pipe open and that is the one that went to 27. added fuel at WOT and still low o2s but no knock.  :rock:
Twins86 you can have that ice fishing I much rather be riding my GN.  but good luck
« Reply #4 on: January 11 2015, 01:39:21 PM »
Ready for the track. :rock:
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #5 on: January 11 2015, 01:40:59 PM »
should get that 10 sec slip now
