The Bastard Child Buick Board
Top of my up pipe rubbed the hood insulator with both HR engine mounts and a precision stretched SLIC. I removed the passenger side engine mount and went with a stock one there. Then put in an HR poly tranny mount. No rubbing after that. LT1 MAF measures almost 3 1/4 on the outside diameter. Have to stretch a 3 inch coupler to fit it but it will go on. I did the exact same thing with the actuator by welding it to the existing clamp on a TE44. It appeared to line up well in the vidShould have stayed on the dudes screen name a little longer in the vid. Did you blast him on a feedback thread?
So you can only get a parallel flow part that can't be flushed should the compressor kak?
