Author Topic: My 1986 Grand National (re) Build Thread  (Read 157976 times)
Offline GavinHunyady
« Reply #135 on: June 28 2016, 11:51:01 PM »
am I reading this right? a blown light bulb can cause the alt not to charge?
http://www.turbobuicks.com/forums/introduce-yourself-community/97267-alternator-not-charging-need-help.html
what in the actual F***?
I also noticed that the hood light all of a sudden stopped working. Bulb looks ok... bad ground somewhere?
« Reply #136 on: June 28 2016, 11:51:51 PM »
I will try to remember to measure one of mine tomorrow.  I think GM says as low as 35 ohms and as high as around 400....I never measure the resistance of one of the little push in dash light bulbs.
« Reply #137 on: June 29 2016, 12:50:55 PM »
so there is legitimately a light bulb that I need to replace?
I swear I'm losing my google fu all of a sudden.
EDIT: found it... and thanks for the clever response.  :player:
So now I see that the light doubles to excite the alt on start up... the flickering bulb could be a bad connection. I'll order the caspers kit (or cobble my own) just to get testing and later get around to fixing the connections in the dash.
« Last Edit: June 29 2016, 01:11:41 PM by GavinHunyady »
« Reply #138 on: June 29 2016, 01:15:47 PM »
The light bulb in the dash is the only bulb involved. It is flickering so it is not burned out.  That bulb serves as resistance to drop the voltage a tad to avoid burning up the alternator .  Some GM cars had a resistor paralleled across the bulb in case the bulb burned out.  I've not seen one on a Regal but there might be some.
The question is this:  Is the alternator bad, or does the bulb in the dash have a flaky connection to the  pc mylar.  If you want to find out, rig a jumper with a small bulb in the middle to act as resistance.  Hook one end to the battery or back of the alternator post and the other end into the brown wire coming from the dash.  When you turn the key on, this bulb should light up and burn steadily.  When you start the car up, the light should go out and the alternator should be charging.
If the alternator is not charging, then you have a bum alternator.
« Reply #139 on: July 03 2016, 01:16:32 AM »
Here's the latest VLOG, but you guys already know all the gory details.
https://youtu.be/WjonfgKBQr0
« Reply #140 on: July 03 2016, 09:28:31 PM »
grrr, oil cooler line started leaking at the rad again.
« Reply #141 on: July 04 2016, 11:11:46 AM »
What's an oil cooler? I guess mine was a factory delete. :)
« Reply #142 on: July 04 2016, 03:09:54 PM »
Mine has that option too!
« Reply #143 on: July 04 2016, 11:35:22 PM »
Mines been deleted as well.  Get the precision remote filter with turbo feed line.  Mounts behind the passenger headlight and feeds the turbo filtered oil
« Reply #144 on: July 05 2016, 09:32:52 AM »
Whats the logic on deleting it? Just the reduction of leaks/threat of  hose failure? I can only assume that the conditions that warranted the use of an oil cooler were driving patterns that I would not see (i.e. davis dam, extended hard track use, nurinburgring, etc) On the other hand, I already have the stuff and would hate to remove something that was required to protect the engine.
« Reply #145 on: July 05 2016, 01:03:31 PM »
Reduction of leaks is the big factor. If you must have a cooler, plumb one inline with the remote filter.  Then again, that's another place for leaks
Offline Be4u
« Reply #146 on: July 05 2016, 01:09:53 PM »
One conversation that will never die, oil cooler discussions. :rofl:
Save the bumper fillers!
Move to Canadia!
« Reply #147 on: July 05 2016, 02:12:06 PM »
Finally got around to watching the video log. Car sounds and looks good!
« Reply #148 on: July 05 2016, 04:19:57 PM »
man I searched for one to get the scoop and couldnt find much... my bad.
« Reply #149 on: July 05 2016, 04:30:24 PM »
Steve...correc t me if I'm wrong...but doesn't Billy Anderson have several dozen 55 gallon drums full of oil cooler/adaptor lines. I prolly forgot to mention that I hand out IC fans to the neighbourhood kids as frisbees.
