Author Topic: Cleaning/rebuilding stock D5 or replace  (Read 15937 times)
Offline dyermullet
« on: December 28 2014, 09:58:07 PM »
I am finishing up a rebuild on my brf trans.  I am just doing a stock style rebuild following the CK book.
I have a stock (as far as I know) D5 converter 110,000 miles.  Stock longblock, TA49 turbo, and no plans to try to set the world on fire with this car.  I will take it to the track occasionally but it is a street car first.
How much should I expect to pay to have a shop work on my converter?  What would I need done, replace the lockup clutch, and increase the stall some?
Price wise how does that compare to buying a new converter?  Besides increase in stall is there any major benefit of an aftermarket converter compared to the stock?
Edit:  I forgot to say I am trying to keep my $$ investment in the 2004R platform to a minimum.
Offline GavinHunyady
Re: Cleaning/rebuilding stock D5 or replace
« Reply #1 on: December 28 2014, 10:07:01 PM »
I have a low mile orange stripe I'll sell you cheap, I went to a 9" nlu.
« Reply #2 on: December 28 2014, 11:49:28 PM »
To have it cut open and gone thru with a new clutch should between 200 to 250.
Offline 626gn
« Reply #3 on: December 28 2014, 11:50:04 PM »
Costs would of course depend on where you live. I live in Hawaii and when I priced a restall and cleanout of my D5 it was only a couple hundred less than a new 9.5 from Dave Husek so I went that route. I was on a budget too but never regretted the decision.
’87 Limited – Stock short block, 206/206 billet roller, ported irons, TE45a, FMIC, ATR DP, ATR exhaust, double pumpers, 80lb injectors, TurboTweak AXiS, LS1 MAF, Janis transmission, 9”AC 16930 NL, Alradco dual fans, Eaton posi, Moser axles, ATR sway bar, Kirban seat braces.
« Reply #4 on: January 01 2015, 05:45:21 PM »
How's your assembly coming along? Did you get the servo worked out?
Should be someone local there in H-town that the racers use.
« Reply #5 on: January 01 2015, 05:53:05 PM »
I'd have the trans swapped to a NL configuration and go with an off the shelf 2800 NL PTC convertor for that TA 49.
