I have been having lots of problems with my new 2004r. The builder has stopped responding so I guess I am on my own.
disclaimer - The TV cable is set properly, the fluid is full and I am not a dumbass (but troubleshootin g this trans is making me feel like one).
At part throttle (below half), starting from a stop the trans shifts very late into second gear. I hold constant throttle and the car gets over 4000rpm and just stays there and finally it will shift.
Starting from a stop WOT, the trans will not shift out of first gear. It just stays in first gear, until I lift the throttle. Once it is in second gear I can accelerate with part throttle, if I give it any significant amount of power in 2nd gear the trans slips. 3rd gear appears to work.
I have taken pressure measurements I will go get my notes and post in a minute.
Before I smoked the 2nd gear band I was having a multitude of problems. The trans would shift late and hard 1-2, and 2-3. I checked and double checked the tv, even took the pan down and checked. Made no changes drive the car and the late and hard shifting was gone. Park the car in the garage, change nothing, drive a few days later and back to shifting late and hard. I think their is something wrong with the "special" TV spring and plunger my builder uses. I was planning to try taking the TV parts out of my stock trans and swap into this one. I need to find out what is wrong with this thing before I tear it down to fix the band.
Thanks in advance.
Scott
