Zap *STILL* wears Depends
Data Log ATTN STEVE
Topic: Data Log ATTN STEVE (Read 2415 times)
TurboCajun
Keith Theriot
Turbo Street Modified
PSI: 1
6 Packed
Data Log ATTN STEVE
December 07 2014, 02:04:37 PM »
I dont see anything wrong maybe I am missing something
Re: Data Log ATTN STEVE
December 07 2014, 05:15:02 PM »
me, neither
Scoobum
December 07 2014, 07:49:43 PM »
02's are at 741 in high gear at 91 mph and 5500 RPM. If I was gonna push it any harder in high gear I'd throw fuel at it.
Data Log ATTN STEVE
December 07 2014, 08:02:24 PM »
He discovered the fpr would not hold pressure but he was trying to find out why it would not make boost. Turns out his new dp will not seal
TurboCajun
Keith Theriot
PSI: 1
6 Packed
December 07 2014, 09:53:25 PM »
what a rough weekend , it started Friday midday making the plate to go between the turbo and down pipe, thinking that was the problem. did not figure out the problem till late this afternoon , i think that I put Steve's brain to the test and had him stressed as much as me. Thanks so much Steve. now I hope that I don't have any issue with RJC making this good. well at least we know it's not the engine causing the problem
TurboCajun
Keith Theriot
PSI: 1
6 Packed
Reply #5 on:
December 07 2014, 09:56:04 PM »
here are some pictures, one is a thin plate that i made without the wastegate hole that you can see where the puck is sealing and where it is not.
Data Log ATTN STEVE
