The Bastard Child Buick Board
Fuel pressure
Topic: Fuel pressure (Read 1995 times)
TurboCajun
Keith Theriot
Turbo Street Modified
PSI: 1
6 Packed
Fuel pressure
November 30 2014, 09:47:59 PM »
Turn the key on fuel pressure goes to 40 psi but as soon as the pump stops the pressure goes down to 30 then slowly bleeds down. Fairly new pump, regulator and gauge, I seem to remember on a freinds car that his does not drop
Re: Fuel pressure
November 30 2014, 11:38:46 PM »
can be a sorry check valve in the pump, leaky injector, or a bad diaphragm in the regulator...No
rmally it drops more slowly than that
did you figure out if the puck was not covering the hole?
TurboCajun
Keith Theriot
PSI: 1
6 Packed
Re: Fuel pressure
December 01 2014, 08:42:33 AM »
no Steve I haven't , but will try to check it during the week.
Fuel pressure
