Author Topic: Rotating Assembly Balance Question  (Read 12989 times)
« on: November 16 2014, 12:50:31 AM »
I always have the rotating assemblies balanced in my engines...cuz they rev out as smooth a silk. Is there a distinct HP/performance advantage to this...and if so...why?
Offline The Radius Kid
Re: Rotating Assembly Balance Question
« Reply #1 on: November 16 2014, 01:20:10 AM »
Eeyup.
It works for the same reason balanced airflow to each cylinder does.
It's the old synergy and a rock under the rim of the Frisbee analogy.
« Reply #2 on: November 16 2014, 10:15:18 AM »
John, you are still the best!
« Reply #3 on: November 16 2014, 10:17:02 AM »
Are there not many pieces to this balance thing? Aren't 3.8's balanced differently - not 50/50? If only we knew a machinist ( cough Radius) who knew these things?
« Reply #4 on: November 16 2014, 12:04:40 PM »
Thanks Steve,but I can't take credit for my knowledge.
I was taught by the best,but I'm still learning .... or something like that.
« Reply #5 on: November 16 2014, 12:09:06 PM »
You're confusing the balance specification with the need to balance or not,if I read this right?
« Reply #6 on: November 16 2014, 02:49:03 PM »
No, I inquire of this et al :
"The balancing took care of the vertical component of the vibrations and the motor mounts took care of the horizontal component."
http://www.gnttype.org/general/v6hist.html
