Author Topic: injector swap  (Read 9802 times)
injector swap
« on: November 11 2014, 10:15:50 AM »
Well, car was idling like crap. I bought some new to me 42lb injectors and a matching tt chip. It is the 5.6 version so we will be learning some tuning. Should be fun.
Stock injectors
This one had some wear.
Old chip. Kenny Duttweiler special
We also replaced a bunch of old vacuum lines. I hope that helps with our low boost on the gauge.
Idled much better but then the water pump started pissin out the hole. So now we need to do a swap Out that. Never ending.
« Last Edit: November 11 2014, 10:44:12 AM by TexasT »
Re: injector swap
« Reply #1 on: November 17 2014, 12:10:07 PM »
It should run a lot better now.
Re: injector swap
« Reply #2 on: September 10 2018, 06:55:36 AM »
It is also almost four yrs old
