Author Topic: Troubleshooting the AC  (Read 19271 times)
Offline gordyzx9r
  • The Sultan of Swank
Re: Troubleshooting the AC
« Reply #15 on: February 07 2015, 03:27:18 PM »
Well, it was just about empty apparently.
Had it recharged and everything works again and blows cold.  I guess almost 2-3 years of having the motor ripped out multiple times it lost it's charge somehow?  Hopefully it's not leaking.
« Reply #16 on: February 09 2015, 10:19:26 AM »
the clutch seals will usually leak after sitting for awhile.  Many will turn the ac on once a month during the winter for a few minutes to try to avoid this.  I would have it checked for leaks altho they should have pulled a vacuum on the system before charging it and let it sit to see if it held it. They may have just put freon in it, tho.  If it is leaking slowly, it may be cheaper to put one or two cans in it every year than pay a fortune to have it fixed....:D
Offline 278CIKILLER
« Reply #17 on: February 09 2015, 12:20:38 PM »
I have a good used AC compressor out of a 87 GN if you need one.
« Reply #18 on: February 09 2015, 02:04:51 PM »
I agree with Steve. When I got my 04 Denali the air wasn't that cold. Freon was down but they couldn't find the leak?
So I topped it up & all was fine until a year later & it wasn't cold enuf again. Added a can of the Leak Sealer with a can of Freon & it's been good for 5 years now. I figure the leak was somewhere in the roof since the 2nd lines go to all the back seat vents & that would have been a major PITA or lot's of $$ to pay a shop!
Offline gordyzx9r
« Reply #19 on: February 11 2015, 11:28:11 AM »
the clutch seals will usually leak after sitting for awhile.  Many will turn the ac on once a month during the winter for a few minutes to try to avoid this.  I would have it checked for leaks altho they should have pulled a vacuum on the system before charging it and let it sit to see if it held it. They may have just put freon in it, tho.  If it is leaking slowly, it may be cheaper to put one or two cans in it every year than pay a fortune to have it fixed.... :D
Yeah, they leaked checked it.  I watched them do it and they talked me through what they were doing.  I primarily did that just because as soon as the shop foreman pulled the car into the bay all 10 of their techs came running over, whipped out their cameras and started taking pics.  I kinda felt bad for their other customers because the mechanics stopped working on the other cars and just kept drooling over the GN the entire time it was there.
And I got some of the usual TR cliches like "my brother had one, but put in a 400 to make it fast", "why don't you take out that six and put a 400 in it...".  I was kinda surprised they said 400...and not 350.
