Author Topic: Troubleshooting the AC  (Read 52497 times)
Offline gordyzx9r
  • The Sultan of Swank
« on: October 29 2014, 06:16:57 PM »
So:
The AC & Heater system.
I haven't used the AC in years.  It was converted to 134 awhile ago.
I charged the system.
When I turn the AC on maximum, I hear a click sound, the RPMs alter slightly, and air blows through the vents...but it doesn't get cold.
When I set the controls to heat, heat blows out through the floor vents only, it doesn't come out the console vents.  If I set it to vent and set it to hot, I get hot air.  When I set it to defrost, it seems to be working correctly.
When you set it to heat, should it blow air out the console vents, or just the floor vents?
Where do I start?
Re: Troubleshooting the AC
« Reply #1 on: October 29 2014, 07:18:21 PM »
first check the end of this cable behind the glove box   http://www.vortexbuicks-etc.com/heater_cable.htm
and if that is actuating the door properly, check this  http://www.vortexbuicks-etc.com/acvacuumswitch.htm
« Reply #2 on: October 29 2014, 07:33:09 PM »
Believe Kirban has now cloned the discontinued lever.
otherwise my hack?:
http://dtekk.com/automotive/heater/heater.html
Offline gordyzx9r
« Reply #3 on: October 29 2014, 07:53:37 PM »
Thanks, I'll check those out.
FYI...on http://www.vortexbuicks-etc.com/acvacuumswitch.htm the instructions/text between pics doesn't show up unless you highlight it.  I checked in FF and IE.
« Reply #4 on: October 29 2014, 08:06:21 PM »
Thanks.... I will fix it
« Reply #5 on: October 29 2014, 08:12:10 PM »
that should do it
Offline gordyzx9r
« Reply #6 on: October 30 2014, 03:26:57 PM »
I'll look at it once I get off work today.
So, I take it that when I set the control to "heat" I should have something coming out of the dash vents and not just the floor vents?
What about the AC not blowing cold air?
Gordy
« Reply #7 on: October 31 2014, 01:22:27 PM »
cold air is stuck if that lever can't move the door, so start there
« Reply #8 on: October 31 2014, 02:03:58 PM »
You said you heard the compressor click...look at the front of the compressor to see if the entire pulley and not just the outer clutch part is turning.
If it is, put your hand on top of the "can" and see if it is cold.
Offline gordyzx9r
« Reply #9 on: December 10 2014, 02:40:50 PM »
The pulley turns, but I don't see anything else turning.  I took a video and posted it on my FB just in case so we can be sure we're talking about the same thing.
Everything behind the control head looked fine as well as behind the glove coompartment.
« Reply #10 on: December 10 2014, 03:38:51 PM »
if the pulley is rotating but the center hub is not, then the compressor shaft is not turning and you will have no cooling.
Pull the connector off the can and jump the two terminals in the connector together with a piece of wire..you should hear a click and the hear/feel the engine load down a bit.  Then, looking at the front of the clutch should show it turning as an unit and not just the outer pulley
Offline gordyzx9r
« Reply #11 on: February 06 2015, 05:41:04 PM »
I know I'm slow...
Okay, so when I jumped the terminals in the connector the clutch started turning and there was a load on the engine.
Offline gordyzx9r
« Reply #12 on: February 06 2015, 06:00:46 PM »
So, low on Freon or the low pressure switch is bad?
« Reply #13 on: February 07 2015, 10:30:52 AM »
that would be a good starting place....need to put a gauge on the low pressure side and see what it reads...You can use one of those cheap gauges they sell with the 12 oz cans of freon if you like...connect it to the low pressure fitting on the system, jump the switch and see if the pressure is in the green on gauge..or above say 25 psi if it is not marked...if it is not, then it would appear to be low...
If the car started to cool (put your hand on the line going into the evaporator) when you jumped the switch...then you know the switch was bad.
Offline gordyzx9r
« Reply #14 on: February 07 2015, 11:32:56 AM »
No, it did not cool.  I'll get the pressure level checked.
