Author Topic: valve train noise  (Read 5680 times)
Re: valve train noise
« Reply #15 on: November 04 2014, 12:40:58 PM »
dosent make the noise in park, gotta drive it to hear it? Its lifters or exhaust leak...leaning towards a bad lifter.
Offline dyermullet
« Reply #16 on: November 04 2014, 12:48:58 PM »
did you confirm no exhaust leak.  I would suspect that first before lifter.
