Author Topic: Compressor making noise  (Read 13656 times)
« on: October 21 2014, 11:02:39 AM »
Compressor making noise. I sprayed it with wd40 and that quieted it down. I haven't used the ac in at least twenty years. I'm sure it needs a compressor but that ain't in the budget this year. I've been googling and I'm not sure if I should try to replace the pulley bearing or just buy the A/c delete pulley setup and go with it until I can afford a new compressor. Wife went to eye doctor, needs kateract surgery to the tune of $3900. No ac for me for a while but I do need to drive the car.
Any thoughts? I think I can use the loan a tool thing at az. I have a 3 jaw puller just nee the clutch puller and clutch installer tools if the google results are what I'm going to do. Also does anyone have the bearing number I will need for a stock compressor pulley.
TIA
Re: Compressor making noise
« Reply #1 on: October 21 2014, 07:01:24 PM »
Is this similar to what I'm in for? I know this is the older compressor but maybe the clutch is similar.
http://www.bernardembden.com/xjS/comclutch/index.htm
« Reply #2 on: October 21 2014, 09:15:10 PM »
Ask around locally if someone has one they pulled out to use for the interim?
« Reply #3 on: October 21 2014, 09:39:38 PM »
« Last Edit: October 21 2014, 09:49:59 PM by daveismissing »
« Reply #4 on: October 21 2014, 10:11:59 PM »
I've got a spare compressor that came with my barn engine. It's yours if you would like it
« Reply #5 on: October 21 2014, 10:30:17 PM »
Be a tuff guy like me...and roll down the windows. :)
« Reply #6 on: October 21 2014, 10:45:25 PM »
That's how I roll.... except when the wife is in the car
« Reply #7 on: October 21 2014, 11:23:56 PM »
I'd love to have it. Let me know how we could get it from there to here? Shipping to 76017
« Reply #8 on: October 22 2014, 06:38:03 AM »
I've been doing that for twenty years. I just don't want the pulley bearing to seize up and ruin my day. Mine doesnt even have power windows to add to the low budget tough guy mantra.
« Reply #9 on: October 22 2014, 08:48:12 AM »
I'm in Gatesville and can meet halfway if you like.  That way I don't have to worry about boxing it up. How about Hillsboro?  Pick a date preferably on a weekend
« Reply #10 on: October 22 2014, 11:31:47 AM »
I'll have to see what I can work out for a meet up
I found two different remove/install tools on the Napa site. Anyone know which will work?
http://m.napaonline.com/parts/PartsDetail.aspx?k=NTE781312_0407703742
http://m.napaonline.com/parts/PartsDetail.aspx?k=NTE781317_0063340606
They look similar.
Tia
« Reply #11 on: October 23 2014, 03:34:31 PM »
Rich, we're headed to cold season in PA. You can borrow my stuff for a couple of weeks if shipping is cheaper than buying. I think using Jason's compressor is a good idea too.
« Reply #12 on: October 24 2014, 09:39:35 AM »
I certainly appreciate the offer but I don't mind buying tools. I just need to know which ones will work. I seeing that we have an r4 compressor, is this correct?
Summit has these and they are surely Chinese as the ones I could get at Napa.
http://m.summitracing.com/parts/oes-27002
http://m.summitracing.com/parts/oes-27007
Do these look like they will work?
« Reply #13 on: October 24 2014, 01:08:51 PM »
Here is a cheap set on eBay that might do others than just my Buick.
http://m.ebay.com/itm/371031021906?cmd=VIDESC
« Reply #14 on: October 28 2014, 06:04:37 PM »
I got my Snap-On set and compared to the E-bay set and if its legitimate, it has all you need. The two lower tools are what you need, and the center picture that looks like a washer should be a bearing for when pressing back on the compressor.
