Author Topic: track day!!!  (Read 13243 times)
Re: track day!!!
« Reply #30 on: October 21 2014, 04:31:07 PM »
Thanks!! Plan on getting some nittos next spring. How much boost can a guy typically leave with on those. I understand track prep is a factor but just wondered. On these I was usually leaving on 5-6 lbs.
Re: track day!!!
« Reply #31 on: October 23 2014, 06:53:16 PM »
Skip the nittos and go for some MT Drag Radials - leave @ 10-15psi off the ebrake  :rock:
That alone will get you close to an 11.99 if not a little quicker
Re: track day!!!
« Reply #32 on: October 26 2014, 05:28:02 PM »
I don't know about the ebrake, that could tear your backing plate out.
Re: track day!!!
« Reply #33 on: October 26 2014, 05:38:58 PM »
Yep
Re: track day!!!
« Reply #34 on: October 26 2014, 06:29:30 PM »
Line lock. You can leave with lots more RPM. One on my car is so simple...even a cave man can hook it up.
Re: track day!!!
« Reply #35 on: October 26 2014, 06:50:00 PM »
Which one you using?
Re: track day!!!
« Reply #36 on: October 26 2014, 06:53:56 PM »
Jack Cottons
Re: track day!!!
« Reply #37 on: October 26 2014, 06:55:28 PM »
And Grumpys ashtray switch. :)
Re: track day!!!
« Reply #38 on: October 26 2014, 07:22:50 PM »
Here's a couple of pics I just took. Unscrew the line from the MC and screw it into the roll control...and install the other line Jack sends. Wire it...and you're good to go.
Re: track day!!!
« Reply #39 on: October 26 2014, 07:30:43 PM »
Yes...that's a fire extinguisher.. .and it fits tightly between the seat and the console. I've seen way too many guys stop haifway down the track...or at the turnoff road...and stand there and watch their pride and joy burn to the ground.
Re: track day!!!
« Reply #40 on: October 26 2014, 07:39:52 PM »
Note the hotwire kit...think the one in the pic is for the pump...and I have the other from Jack at Racetronix for the injectors...an d Caspers V plus volt booster. Guys, I can't stress enuf how important it is that you supply these engines with the fuel pressure/volume they require. You wouldn't believe the PL files I look at where the voltage is in the 12's...and the guy is wondering why he's seeing KR...or why he tossed a set of head gaskets.
Re: track day!!!
« Reply #41 on: October 26 2014, 08:12:16 PM »
Damn smart!
Re: track day!!!
« Reply #42 on: October 26 2014, 08:25:45 PM »
Everything on my car is plug-n-play. No cut/slashed wires etc.
Offline tb3
Re: track day!!!
« Reply #43 on: October 27 2014, 01:30:03 AM »
 :rock:
I carry one in my trunk, attached to the underneath of the rear deck
Offline tb3
Re: track day!!!
« Reply #44 on: October 27 2014, 01:34:40 AM »
your power steering bracket needs to be bead blasted and repainted.  Its got some corrosion on it.   :icon_lol:    lol.
Everythings lookin pretty good!  I like the brake line formed nice and neat and not the stocker just twisted around to fit
