Author Topic: Rear Sway bar  (Read 1915 times)
Rear Sway bar
« on: October 10 2014, 11:09:10 AM »
So I have the Hellwig rear bar. For best launch I want this set harder or softer. I thought harder. It has 3 holes in bar ends and also an adjustable drop link for fine tuning I guess. I currently have it set in the hole in the end which I think is the softest setting, so my understanding is to increase stiffness I move to the middle and then hardest setting would be the hole 2 inches in from the end?
Rear Sway bar
« Reply #1 on: October 10 2014, 01:24:45 PM »
I'm curious also.
Also do you preload the PS by shortening it or lengthiness the DS links?
Re: Rear Sway bar
« Reply #2 on: October 10 2014, 01:49:03 PM »
you want it stiffer so put it in the short hole so the leverage is less
