Author Topic: Nocooler's Next Stick!  (Read 3715 times)
« on: October 07 2014, 09:34:21 AM »
Re: Nocooler's Next Stick!
« Reply #1 on: October 07 2014, 03:18:53 PM »
Best times were with the 8-speed auto.  I would love to have that car.
« Reply #2 on: October 07 2014, 04:06:59 PM »
Would love to have that  :rock:
« Reply #3 on: October 07 2014, 09:51:33 PM »
It'd be fun. Bet it doesn't make the crunch my faceplated box does  :O
« Reply #4 on: October 08 2014, 09:13:01 AM »
There is a point (in my opinion) where shifting gears too many times takes away from the fun - too much to think about.
The performance is notable.
« Reply #5 on: October 08 2014, 09:34:44 AM »
I agree whole heartedly about shifting gears.  It gets to a point where it's work and not play anymore
« Reply #6 on: October 08 2014, 10:46:14 AM »
thats a ridiculous car
« Reply #7 on: October 08 2014, 09:43:35 PM »
The work truck I drive is a ten speed, and yes you couldn't give me a manual trans car. It is work.
Cool car but where will I haul the slicks?
