Author Topic: jason's education thread  (Read 113300 times)
Re: jason's education thread
« Reply #225 on: December 18 2014, 11:40:22 AM »
Been playing with the secondhand  external wastegate I got last September.  Still won't control boost.  Took it apart and found the o-ring not sealing between the 2 halfs of the gate.  The leak is located on the boost side of the diaphragm not the vacuum side.  Question is, can I pookie it up with some high temp copper RTV or do I need another o-ring?  This is the 46mm gate from GN1.  I believe full throttle sells the same one.
« Reply #226 on: December 18 2014, 01:36:31 PM »
o-ring
« Reply #227 on: December 18 2014, 03:03:31 PM »
The o-ring is on the outer diameter of the shaft.  In otherwords, the valve does not slide up and down on the o-ring.  The inside diameter where the valve moves up and down does not have any provisions for sealing.
« Reply #228 on: December 18 2014, 04:12:23 PM »
guess you can always clean the rtv off, then
« Reply #229 on: December 22 2014, 11:14:48 AM »
Went back to the internally gated down pipe.  Everything back to normal and then the TPS took a shit.  Looking for a Delco
TPS now....  Going to check with highway stars
« Reply #230 on: December 22 2014, 11:18:14 AM »
I have an off brand tps from O'Reilly on our suburban, working well so far.
« Reply #231 on: December 23 2014, 11:34:12 AM »
Picked up a BWD TPS from Oreilly's.  6 bucks cheaper then highway stars and no shipping costs
« Reply #232 on: February 21 2015, 07:25:10 PM »
Anybody know what this is and where I can get instructions?  Found it attached to an engine harness that I have.  Hoping it helps with setting the cam sensor but I can't tell if that's a caspers brand on the sticker or not.
« Last Edit: February 21 2015, 07:33:58 PM by good2win22 »
« Reply #234 on: February 21 2015, 07:31:22 PM »
Thanks Rich!  I was hoping it was a cam sensor tool.
« Reply #235 on: February 21 2015, 09:23:16 PM »
Glad to help.
« Reply #236 on: February 21 2015, 10:51:01 PM »
throw it away...it does nothing on our cars useful...it's from the old days before we understood how the tps worked
« Reply #237 on: February 22 2015, 04:22:49 PM »
He could always sell it on TB.COM :)
« Reply #238 on: February 22 2015, 05:33:27 PM »
That's what I was thinking about doing
« Reply #239 on: March 07 2015, 10:48:24 PM »
New owner of the white T came over this morning and we installed a 6262.  I am super impressed with the 6262!  Took a photo op while they both were at the house
