Nasty Wendy Isn't
A few things I've picked up on over the years.You'll know you've done a decent launch when the cigarette lighter flys over your shoulder...... .
Something else I would like to pick y'all's brains about. I'm driving it down the track in 3rd and letting the tranny do the shifting. I've notice on the logs that I'll get up to 5600-5700 rpm when the tranny shifts 1-2. But when the tranny makes the 2-3 shift, it's not going up to about 5200. With the 1-2 shift it drops down to around 4700-4800 but with the 2-3 shift, it drops down to 4500-4600. With the 1 to 1 gear in 3rd, is this too low of a drop of rpm? Am I not in the optimum rpm for making power? Should I manual shift the car at a higher rpm? Maybe work the governor to lighten it a bit and continue to let the tranny shift itself?
I love that pic, so if I find a couple rims 7" with a 3 3/4 BS or 8" with a 4"BS I should be golden.
A few things I've picked up on over the years.MPH is indicative of HP.When running the 1/4 shoot for a 25 mph pickup in the 2nd half.Convertor slip percentage, flash stall, and RPM drop at the shift points should be required reading.Leave Erics high gear timing on his default setting. The guys running silly fast times spraying alky are using 18-20 timing.If you're not tuning for low gear...then you're leaving a shitload on the table.Putting your car on a diet is free HP.If you can afford a couple hundred bucks of bling for your car...then you can afford Powerlogger.Instructions are sent along with a product...for a reason.You'll know you've done a decent launch when the cigarette lighter flys over your shoulder.One word. Slicks.
