Author Topic: nocooler's firechicken thread  (Read 304477 times)
« Reply #765 on: October 09 2019, 05:23:18 PM »
At least it'll be up and running.
« Reply #766 on: October 11 2019, 02:05:26 PM »
Spent some time on Struggle Street today.
Car would start run for 20-30secs and stall, spent some time with the tune and didn't get anywhere. I found 4 plug wires that weren't clipped to the plugs. Engine runs and idles now but my boost gauge is showing 5" vacuum, map sensor is showing 50-60kpa which is 15-18" of vacuum. Great I have a leak somewhere, I pulled the line to the brake booster off and it still idled, plug it back in and stick my head under the dash and sure enough seems like the booster is leaking. Push the pedal and no assist. Apparently I broke the oil pressure sensor off when I installed the intake.
But the car is on all 4 tires, starts, and runs. I had one small trans leak, but I tightened the fitting and all was well.
« Reply #767 on: October 11 2019, 02:47:04 PM »
Some days are more frustrating than others....damn boosters do that at times
« Reply #768 on: October 11 2019, 03:28:16 PM »
Take your time Jeremy. I always looked at the Buick as not being my DD...so I took my time. Make sure everything is spot on...before you hit the track. I dunno how many times I had locals show up...when their TR shouldn't even have been there.
« Reply #769 on: October 11 2019, 03:47:15 PM »
My local track is closed for the season. I'm in no real rush. My stuff is usually pretty well dialed in from street pulls before I go and try to make some passes at the track.
« Reply #770 on: October 12 2019, 12:35:25 PM »
Well - I got the booster out today, it's dead. If I play with the seal I can get it to hold 5" vacuum, but as soon as you touch the rod it goes away.
I tested my boost gauge as well and it's toast as well, it leaks internally - it won't hold vacuum or pressure.
« Reply #771 on: October 12 2019, 12:48:34 PM »
I was able to move the master out of the way. It was definitely a challenge pulling it out. You pretty much have to fight the cowl, strut tower, and the valve cover for space.
« Reply #772 on: October 12 2019, 01:42:49 PM »
Nasty fitment-kudos on being a contortionist.
« Reply #773 on: October 12 2019, 04:06:28 PM »
OMG!!!! RUST!!!!
« Reply #774 on: October 12 2019, 10:12:47 PM »
Yup that's where the clutch master was, doesn't take much brake fluid to create rust.
« Reply #775 on: October 17 2019, 02:49:22 PM »
Got the booster and boost gauge in today.
I spent most of the day diagnosing a no start issue. Turned out to be my key. Checks at 4100 ohms were the spare key was 4700 ohms. Spare key makes it through the security reset procedure, the other does not. So the car runs, has power brakes, and a working boost gauge. Time to start tuning.
« Reply #776 on: October 17 2019, 04:53:49 PM »
Jeremy. It'd be great to do vids of what you're using for fuel management and how to tune it step by step. Remember...not everyone's as smart as you. Keep it simple and dumb it down. There's a million Scoobs wandering around out there. Scoob will flood you with questions on your channel.
« Reply #777 on: October 17 2019, 04:59:52 PM »
For instance. Do a vid on how to ohm a key. Scoob hasn't got a clue.
« Reply #778 on: October 18 2019, 11:05:59 AM »
I'm taking a day off from the car, my body is pretty pissed today. After working on the car most of the day yesterday I came home and changed a hvac zone damper motor. The old ones failed closed, so I pried them open for the a/c to work. But I'm really sick of the uneven heat so that was enough motivation to get after it. It took some backyard engineering, as it was not a direct replacement. I came up with a piece of 1" long 5/16 rod to use as a drive pin and a 1" long 6-32 machine screw to extended what I would call a locating pin. After that smooth sailing, 2 wire hook up, and it worked. I've got another motor on the way as I had 2 bad ones. I'm saving a good chunk doing this myself. These honeywell motors are sweet - https://smile.amazon.com/gp/product/B01GWW9M6W/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
« Reply #779 on: October 18 2019, 12:07:57 PM »
good deal!
